Kez
- May 31, 2020
- Charlotte, NC
- 2023 High Tide (Punk’n)
Following up.Called my dealer yesterday and they were immediately helpful, and said they wanted to get me in quickly especially since I had very recently purchased the Jeep. Told me to bring it in first thing this morning, 8:00am.
Pulled up and told the service advisor of my issue - Jeep wanders, especially at interstate speeds, and I have about a 1.5” dead spot in the center. Have to saw back and forth to stay tracking straight. I mentioned this new TSB, and he said “it sounds exactly like what you’re describing. We had a Wrangler in last week where we were trying everything to figure out the dead spot, and the engineers called us and gave us a heads up on the new box. - I bet yours is the exact same problem, but we’ll let the techs figure it out for sure.”
Waited there, and in 1hr 45min they came back to me and said “techs agree with you. We will place the order for you first thing Tuesday and it should hopefully take about two weeks to come in.”
They ordered the 68507569-AA steering box and related bolts.
I’m thankful it was a short path to getting the new box ordered, and that the dealer took me seriously and was helpful.
Now here’s to hoping it fixes the dead spot. Will update after the part comes and it’s installed.
It took the dealer about a month to get the parts in for me instead of the hoped for two weeks. They told me it was the bolts they were having a hard time getting in - I figure at least they were aware of and wanted to use the right bolts! I dropped it off Wednesday morning and picked it up Friday morning. Check it over right away, and it had the black box with the right part number on it (68507569AA). Correct bolts were used. Minimal spilled power steering fluid visible, which I appreciated.
Immediate first impression upon startup was that turning the wheel had a bit more "weight" to it, as reported by some others. It felt solid and purposeful. I hopped on the interstate immediately and am pleased to say that there was no detectable dead spot in the steering! Previously had about a 2" dead zone. I'm overjoyed.
I found the best way for me to visualize and confirm the change before and after was sitting in my garage, Jeep running, and turning the steering wheel far enough left until I could see a decent portion of the tire while hanging my head out the driver's window. From there, moved the steering wheel. With the old aluminum box, the tire moved none while the steering wheel moved about 2". Now, same scenario with new box, I turn the steering wheel just a hair's amount and the tire moves immediately too. ZERO dead spot.
I sort of had to re-learn how to drive the Jeep on the way home. There are a lot of curvy back roads to and from the dealer. I was so used to overcompensating that it took me a good 5 minutes to feel comfortable with a Jeep that responds as it should.
Especially if you have similar symptoms, I highly recommend doing whatever you can to get this TSB performed.
