SlickRickMotoADV
Rick
El Sobrante, CA
2019 Wrangler Unlimited Sahara, 2017 Miata Club RF
I just had this done recently and was under my vehicle installing some rock rails today. I noticed that they completely replaced my track bar as well. Everything under my vehicle was covered in mud, except the shiny new track bar. The vehicle steering requires noticeably less attention to go straight.
Any reason they would have replaced it for this TSB? Not that I'm complaining.
Related question; when installing a new track bar, do you need to perform an alignment?
mikem20
Rocklin, Ca
2020 JLUR
I donā€™t see you needing an alignment with a tracbar replacement. Itā€™s function is to locate/ keep the axle side to side. If itā€™s driving well and no issues, enjoy it! šŸ‘šŸ»
SlickRickMotoADV
Rick
El Sobrante, CA
Thanks for that info. I was more curious why they would replace the trackbar without telling me, or without it being part of the TSB. But hey free stuff. Either way, the steering is now way way better :)
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
I believe the new TSB has notes about swapping TB first if not completed.
roaniecowpony
Retired Engineer
If your JL is an early model, it would have a trackbar that had the softer bushings. They revised the trackbar with stiffer bushings. If I recall, the TSB has the technician verify the trackbar is the latest version.
Installing a new trackbar does not require an "alignment" in it's pure sense, because the relationship between the left and right wheels is not affected. But an adjustment of the draglink might be required to center the steering wheel, in some cases.
SlickRickMotoADV
Rick
El Sobrante, CA
You guys rock with all this info and knowledge. Thank you for the explanation, I appreciate it.
Harrybeerbelly
Cleveland Ohio
2020 Tackhawk
Had the TSB done a few months ago, steering had improved but it was only temporary. The loose feeling returned about 2 weeks ago.
Same here. Had it done a few weeks ago and was greatly improved. Now we are back to the same shit. I did check all the fasteners, each one is rock solid tight.
Guess its back to the dealership.
db_racer
Toronto
2020 Jeep JL Saraha
Just gonna chime in with my experience. Have a 2020 Jlu sahara. Noticed from moment I drove off lot that steering wasā€¦ different? Delayed reaction type loose feeling. On way home I noticed it was ping ponging between lanes requiring very attentive steering. Tire pressure was insanely high so lowered to 38ish and steering improved nicely.
Drove for 10000 km never really satisfied with the the steering until first oil change... exhausting on longer higher speed drives. Mentioned steering wander to the service advisor who knew all about the issue with aluminum steering boxes and the new steel ones. He order the parts without any prompting on my behalf.
Took about a month but parts came in and had service done today. Took it for a longish test drive to gather impressions.
Night and day.
Before I had about 1ā€ to 2ā€ dead spot sawing the wheel left to right. All Gone. Now it feels like 1/8ā€ turn and vehicle instantly responds. Soooo much better. Feels precise. Box swap also fixed some bump steer / shudder I was noticing recently.
Would highly recommend for those sitting on the fence wondering if it was worth their time.
Cahlheim
Missouri
2021 JLUR 4xe, 2019 JLUR, 2013 C63 AMG
Technology
Night and day.
Thanks for sharing. I am out of warranty and will likely need to buck up and pay the roughly $1,100 out of pocket. That is unless the agent assigned by @JeepCares can help. Fingers crossed.
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
Did you ever take in for steering concerns prior to warranty expiration? If yes, then it was on record.
Cahlheim
Missouri
Technology
Yep, thatā€™s what I am hoping will be my saving grace. That said I am Metalcloakā€˜ed on 37ā€™sā€¦ so I half expect that they will attribute the wandering to that and say ā€œsorry budā€.
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
Nah. There is also wording in TSB that states lifted within specs still qualify. Unless your dealer wants to be an a$$ about it. Mine was in warranty but had Mopar lift, aftermarket TBs, aftermarket Fox ATS SS, and 37s and dealer swapped with no questions asked. That was even before TSB mentioned lifts. Good luck man - I know it can be frustrating.
Cahlheim
Missouri
Technology
Well, just got the wrangler back and whoa what a difference in steering feel and control. Itā€™s an even more drastic difference than I had hopedā€¦ night and day. My dealer was really gracious about doing the repair out of warranty and asked only that I pay for the alignment. I thought that was very fair as they very well could have told me to go F myself. Super cool of them. I really hope there isnā€™t some sort of regression back to crappy steering, but for the moment I am thrilled with the results.
It is also worth calling out that Kate from @JeepCares was great to deal with.
