Jeep&dogs
Jim
Cedar Lake
2020 JLUr
Anyone wondering why one Jeep drives good with the new box and one doesn’t......this is the spec for the over center adjustment. Keep in mind every one of these boxes get the final adjustment by hand, there is a 4.5 in. Lb variation that is “acceptable” the box set at 1.3 probably still has quite a bit of dead spot, the box at 5.8 probably has close to none....
spudf16
Ed
Virginia
2019 JL Rubicon 2-Dr
Mikester....WOW! I haven’t seen anything about this. Pretty eye opening, and helps shed light on why we see so many different driving box experiences. I will definitely save this in case I decide to adjust this myself. Per chance, where did u find this?
Jeep&dogs
Jim
Cedar Lake
2020 JLUr
I got it from one of the FCA engineers
Jeep&dogs
Jim
Cedar Lake
2020 JLUr
And FYI, here is the wiring schematic for the EHPS system. Power,Ground, Ignition, and power and ground from the CAN buss system. No inputs from any other sensors. Pressure is 100% adjusted by RPM and voltage and a few safeguards built in if the system loses input for RPM. No different than a belt driven pump.
spudf16
Ed
Virginia
Sorry - I erroneously called you Mikester. Thanks for all this info!
jlgolfcart
Southeast Michigan
Bikini JLRU
Somebody that knows what they’re doing needs to do a YouTube video on how to adjust the steering box. Anything to help get rid of the dead spots in the steering wheel.
jlgolfcart
Southeast Michigan
Bikini JLRU
So I just went on YouTube and found that there is videos showing how to adjust the box. I guess I should’ve did my research first.
Jeep&dogs
Jim
Cedar Lake
2020 JLUr
That’s kinda a enter at your own risk type of adjustment. The proper way is described in the doc I posted. It’s out of the Jeep, fluid is removed, and there are several measurements taken. Most people don’t do that. They back off the nut, tighten the screw and then tighten the nut while it is in the Jeep......world of difference in the process.
rayzjeep
Ray
Melbourne, FL
2019 Jeep Wrangler Rubicon Unlimited
Aerospace Engineer
After getting mine home after replacing the box I went to check the torques...everything was under spec...the 4 box bolts and the sector shaft nut. Tightened the 4 bolts to 100ft/lbs and the sector shaft nut to 185ft/lbs. Now the dang thing is drifting left/driver.
Do the 4 bolts on the steering box have a sequence of torqueing?
Jeep&dogs
Jim
Cedar Lake
2020 JLUr
No but they are actually torqued + 115* or something like that. 100ft lbs is pretty close to what they end up at
Levin_tom
Tomas
Jeep Wrangler JLUR
Is there an updated TSB that shows part number AB for latest box?
SleepEatJeepRepeat
Michael
Newport Beach, Ca
2021 JLUR, 2020 Audi Q7
Looking at Jeep stuff all day
So does anyone know for sure if the 2021s are shipping with the new steering box?
#1 for me
Kevin
Bowling Green, KY
2019 JLUR Bright white loaded ordered 9/18 Corvette, z28 Camaro, Mustang GT, Chev z71, GMC Canyon, Yamaha YXZ 1000rss, Yamaha 660 Raptor
UAW GM Corvette Assembly Plant QC .
Done Right LED
