Geekjeep
Turns out my replacement box may have issues. The notchy steering has been isolated to the box. I’m waiting for the replacement. Let’s see how it goes
I'll be curious if the notch steering on my end turns out to be the same thing. Jeep goes in on Monday. Crossing my fingers the dealership can see the same issue I am, isolate and fix; because I'd almost rather have the old box at this point.Dealers can only order a part every week or so. I don’t think it’s a back order as much as there’s a bottleneck of how quickly dealers can get them. As an FYI. I ordered mine the day after the tsb came out. I’ve been dealing with a notchy issue since then. Dealer feels it’s the box and ordered another one. I have no eta on the new box yet.
Just got mine back, radio was NOT reset and I'm pretty sure all the work including flashing the software was performed correctly.Just to confirm... with the flash update as part of the TSB... did everyone loose their radio presets..? Or is there another way to check to see software version?
I had to wait almost 11 weeks to get mine.How are people getting this tsb done? How did your dealer get the parts? I have been waiting for the parts for 6 weeks. The dealer said national back order and didn’t know when they would get them.
Good To hear your jeep is all fixed! My 2021 JLUR has the steel gearbox from the factory and the steering pump is also extremely loud. Did they tell you what they did to address your steering pump noise issue?Quick update. Had my JLUR swapped to the new steering box about two weeks ago. After picking it up steering felt much better but it was notchy and grabbed a bit when turning to the right...also the steering pump was really loud and noticeable from inside.
At the same time I told them about the service rear locker light, so they ordered a new rear axle for me. It’s the only fix for now.
I took it in Wed for the rear axle swap and had them look at all the steering issues.
Picked it up today and all is just about perfect. A new tech was assigned my Jeep for the rear locker so he re-checked all the steering. He ended up re-assembling some parts of the steering column and adjusted the sway bar to address the right turn grabbing. Not sure what else he did, but it fixed everything.
Now I just hope my rear axle sensor lasts another 30,000 miles.
Good luck to everyone else. My steering fixed...I’m outta here.
Well, if anyone has any questions I’ll be hanging around. I know some have the notchiness as well.
I wish mine was stiff. The AE aluminum box was stiffer. I should have kept it for the time being.I just had the tsb done and The steering is better and a little stiffer. I was one of the lucky few that had good steering from the start, but I’ve only driven trucks, my YJ, and older vehicles so I can deal with some wonder. I am quite happy with the improvements.
BUt, what I’m not happy with is the Explosion of steering fluid that the service tech got all over the engine bay. The tech wiped some of it down, but really, how did he get it on the engine cover? The frame rail is soaked and it’s splattered everywhere. I’m not bringing it back so I will just have to go to a self car wash and pressure wash soap into the engine bay to clean it out.
I had a pretty good amount of fluid on my frame. I didn't want dust/dirt to start sticking, so I used Brake Clean to rinse it all off.I just had the tsb done and The steering is better and a little stiffer. I was one of the lucky few that had good steering from the start, but I’ve only driven trucks, my YJ, and older vehicles so I can deal with some wonder. I am quite happy with the improvements.
Well, I spoke too soon about the noise. There's no more notchiness or grabbing when I turn to the right, but after the Jeep warms up I can hear the noise. The noise only occurs when I'm parked and turning the wheel to the left. I suspect this is because all of the resistance/friction its getting by trying to turn the wheel while not in motion. When I'm driving it's not noisy.Good To hear your jeep is all fixed! My 2021 JLUR has the steel gearbox from the factory and the steering pump is also extremely loud. Did they tell you what they did to address your steering pump noise issue?
