“All that” took about 30 minutes to install. Post #128 has my list of parts I used. Nice to be able to get in the Jeep and not have to plug anything in.I applaud the effort but all that to be able to use CarPlay is a bit much for me haha.
I too would recommend 67 design phone holder. I suggest one minor change though. I recommend using the 67 design bracket built for the 4Xe unless you need more than two arms.Look at 67 Designs phone holders. I have the rail system and it’s great for holding my phone.
Correct, and no way to change the number of cycles. Even w/ the Tazer.Curious. My Renegade does 5 cycles of the turn signal if you flip the lever lightly up or down. Sounds like the Wrangler does only 3???
Make sure you have a high quality cable (and not the one that came with the phone). Also try to use as short of a cable as you can. The longer the cable the more likely an issue. If it's going to just sit in the console to charge and use CarPlay you don't need a long cable anyway.Hmmm so why doesn’t it work on mine? So odd.
