New Jeep with mystery part found......Can you identify?
2nd 392
Ca
Here's another picture. It has an unpainted spot that perhaps had a bolt or spot weld.
⚠ CAUTION! That discoloration is indicative of the passenger seat disgronafacator’s unobtanium core leaking. Secure to it’s inadvertently removed mount and reinstall immediately! Failure to do so could result in unanticipated passenger seat EJECTION ❗
redracer
Robert
Manteca, CA
2023 4xe Rubicon
that looks like a jack hold down bracket.... for a truck. Nothing that belongs to your Jeep.
JAKE.JEEPER
Jake
Central New York
'23 High Altitude 4xe
Finance Manager
I just found a little metal box piece under my passenger's seat on my 23 4xe last week. It looks like one of the handheld square pencil sharpeners. 🤔
4-play
Sherman
Ohio
2022 JTR
Throw it in your tool box. It’s an engineering trick called “adding lightness”. If you throw it away, chances are you will find out exactly what it’s for and will not be able to find another one.
calemasters
Allen
Springfield, Mo.
2021 Rubicon Unlimited, & Escalade
Retired Mechanical Engineer
It may be a bracket that limits front seat travel (fore / aft) on the seat track.
Tank the Jeep
Greg
Charlotte NC
2020 JL Rubicon Diesel
I’m going to guess it is either:
a suppository inserter,
or a hanger bracket for the powder coat line n the Jeep factory.
Wulfgott
Riverside, CA
2020 PUNK'N 2.0L Turbo JLUR
Meat popsicle
The jack on mine is locked in by itself. No bracket I am aware of.
aggiechris
Austin
2021 JLU 392
It could be a bracket used on the production line and accidentally left behind. Maybe checking qc or something like that at completion.
TheOtherMe
TheOtherMe
Rocklin,CA
2019 Sport S
I appreciate all of the carefully thought out responses. They truly represent what I've come to expect from the Jeep community. :LOL: However, and this might surprise some, you were all wrong (edit: except calemasters). I found the equivalent piece on the driver's side seat bracket that was missing from the passenger's side. See photos for details. It was probably welded, but I'll just put it back with a bolt and nut. Thanks for the help.
Jeep Wrangler JL New Jeep with mystery part found......Can you identify? IMG_1708
Jeep Wrangler JL New Jeep with mystery part found......Can you identify? IMG_1709
DaltonGang
Houston, Tx
I appreciate all of the carefully thought out responses. They truly represent what I've come to expect from the Jeep community. :LOL: However, and this might surprise some, you were all wrong. I found the equivalent piece on the driver's side seat bracket that was missing from the passenger's side. See photos for details. It was probably welded, but I'll just put it back with a bolt and nut. Thanks for the help.
Naaa, it can't be that. That would be too simple. Try again.
