New! Jeep JL rockGEAR
Status
Not open for further replies.
RanchoShocks
CA
www.gorancho.com
2013 JKU
Rancho's Front Dana 44 and Dana 30 differential Glide Plate for the Jeep Wrangler JL mounts to the front axle casting, and allows for a much smoother glide over obstacles forward and backwards. The Glide Plate protects your differential casting from direct contact in severe offroad conditions. Works with OE and most aftermarket differential covers. Manufactured from 1/4" high-strength, low-alloy steel and covered in a durable red powder-coated finish.
Rancho® JL Rear Shock and Control Arm Skids
are designed to protect your JL control arms and shock absorbers from rocks and other obstacles. Made from 1/4-in. high-strength, low-alloy steel, these skids will glide over obstacles and keep you moving down the trail. The Rancho Rear Shock and Control Arm Skids bolt-on using the shock and supplied control arm bolts, and are powder coated in a durable Rancho Red. Driver and passenger side skids included.
Jeepsk8
Sierra Vista, AZ
2020 JLUR
The range.
Jeepsk8
Sierra Vista, AZ
2020 JLUR
Sorry, wrong thread :whew:
mer43
Mesa, AZ
'98 ZJ 5.9, '18 JLU
I dig 'em. The front has already had a rough life on the AZ trails and has held up nice. I dropped the jeep on the front one on a waterfall with no other damage.
If I had one suggestion, it would be to design a bracket for the front one, similar to the rear one.
mer43
Mesa, AZ
'98 ZJ 5.9, '18 JLU
Rancho, any plans to make FRONT LCA skids? I beat those up pretty good.
SHYUperman
VA
@RanchoShocks question on the glide plate, did you guys test them with Motobilt diff covers? I tried installing them today and they don't seem to have enough clearance to install the u-bolt (see pictures below). I’m concerned the thickness of the covers is preventing it from fitting and the hole for the drain plug is blocked. Any help is appreciated, I was looking for your glide plate to add protection to the front diff drain plug.
Thanks
RanchoShocks
RanchoShocks
CA
www.gorancho.com
2013 JKU
As far as I know not on this diff cover. Matt
Thanks
Sierra
Sierra
Nogales, AZ
link.sierrar.com
2018 JLU Rubicon, 2015 BMW 328i F30
eCommerce Developer
Do you have listed the Rear Dif Cover for JL Rubicon on Amazon? @RanchoShocks
TrailSnail
Josh
Gilbert, AZ
'21 JL Unlimited Sport S
I haven't heard yet, but I am going to pass this on. :)
@RanchoShocks I'm going to shamelessly resurrect this reallllly old thread to inquire about front LCA skids again... is there a reason you only offer the rear? Can we get R&D to look at the possibility of offering them? I'd really like fronts to match the rears and diff glides!
RanchoShocks
RanchoShocks
CA
www.gorancho.com
2013 JKU
Screen shoting and sending on to my guys again :)
Status
