New Hampshire Oil Undercoating any feedback?
Steeltiger
Tom
Des Moines Ia
2020 Rubicon Recon Sting Gray
Grocery Redistribution Specialist
I was wonder about this product. I searched the forum only found 3 posts that even mention it, positive mentions. Any feedback pros, cons? I read that a lot of you you use and like fluid film but this seems to be a better alternative. The smell for sure. Brine season is just around the corner and while I don't intend on driving it much during the winter I would still like to protect it, just in case I have to go get someone unstuck. I have an 03 F150 FX4 for winter and the brine has taken its toll on it, and would like to not repeat the experience.
Thanks
Captain Skip
Skip
New Hampshire
2020 Wrangler JL Sport S
Happily retired
Just had my new JL done last week. I also have my Chevy Silverado and my wife’s Subaru Outback done. I live in New Hampshire where they coat the roads with salt in the winter so I wanted undercoating. The NHOU product will seep into crevices and never dries so it won’t flake off. Just don’t pressure wash it because you will take it off.
Captain Skip
Skip
New Hampshire
Happily retired
1 warning about NH Oil Undercoating.... I'm installing a towplate for towing my JL behind my motorhome and a wiring harness that plug into the rear lights that connect to the motorhome for brake/signal lights on the JL while under tow. I had to run a 4 wire harness from the rear lights to the front for the plug that connects to the motorhome. I made the mistake of having the oil undercoating done before I ran the wires. I ended up looking like I lost a fight with an oil well. The NH Oil doesn't dry....and the Commander in Chief discovered that it doesn't wash out with normal laundry soap. If you're going to do anything under your rig do it before you undercoat!
Northridge4x4
