New fox shock squeaks. Is it normal or I need to get a new one?
firedude
Bret
AZ
2022 Rubicon XR 392 Stingray
Retired firefighter
Normal. Install and enjoy.
cavguy
Arizona
2020 JLUR
I went through this awhile back with Fox, as long as the shock compresses and rebounds fully it's likely that you will just need to lubricate the shaft of the shock with a rubber safe lubricant - which did work for me! Apparently the shaft seals on some of these shocks are tight which causes the squeaking.
Mikester86
Michigan wishing I was on a trail...
2022 JLR
Jeep Wrangler JL New fox shock squeaks. Is it normal or I need to get a new one? 1672675892997
XX4XEXX
JD
Ca
2021 Rubicon
Mechanical Engineer
This is normal and will go away. Mine have done it in the past. As mentioned you can lube just a tad with PE silicon or a drop of Tri Flow, a drop.
