Diode Dynamics
Summit Sponsor (Level 3)
St. Louis, Missouri
www.diodedynamics.com
2018 Jeep Wrangler
These headlights were designed for maximum performance, and they are the only 9-inch headlights that are 100% engineered and assembled in the USA. With the latest technology and features, they redefine what’s possible for aftermarket headlights!
With OEM-grade quality, the Elite Series headlights will add a switchback turn signal, welcome sequence, a brighter DRL halo with selectable color, and optional offroad lighting and show mode. Plus, you’ll get unmatched performance and output, backed by an 8-year warranty.
Maximum Light Output. First and foremost, the Elite Series LED Headlights provide full LED illumination for both low beam and high beam function, with the modern, rectangular bi-LED projector. This unit provides higher intensity than both the OEM halogen and LED options, shining light far down the road ahead. The beam pattern has a sharp cutoff, with excellent center intensity and strong width, for a fantastic nighttime driving experience. The same projector is installed on both the Elite and Elite Max models.
Welcome Sequence. Anytime you hit the unlock button, your Elite Series headlights will show off their capabilities with a gradual illumination of the LEDs. This provides an unmistakable indicator of the modern technology packed inside. Note that this feature is programmable, and can be easily disabled if desired.
Show Mode. As if the other features weren’t enough, the Elite Max model comes with a patent-pending Show Mode. Whether you’re parked at a show or just want to be seen, you can activate the show mode any time you’re stopped. Choose between four functions: Gradual, White Strobe, Amber Strobe, or Amber/White Strobe. Of course, there’s no need for extra controllers - simply toggle your off-road switch to easily start show mode from your cabin.
Selectable DRL - On the Fly. These headlights feature a selectable DRL, to customize the look of your Jeep. With up to four distinct DRL modes, you can choose white and amber colors, and enable or disable the extra DRL bars (if equipped). The best part? You don’t even have to pop the hood. Our patent-pending technology allows you to program your headlights from inside the vehicle, using existing controls. No extra switches, wires, or controllers required!
Switchback Turn Signal. Stock headlights don’t have a turn signal. Where’s the fun in that? The Elite Series headlights will flash amber any time the turn signal is activated. When you’re done making your move, they’ll switch back to the white parking light, or your selected DRL color. With the plug-and-play harness included, no wire splices are needed to add this function. Thinking about a fender chop? The Elite Max model also provides enough turn signal output to be SAE compliant, replacing your factory turn signal completely, unlike the LED strips found in most chop kits. If you’re serious about off-roading but want to stay safe, the Elite Max is the perfect solution.
Not just on road! First in its class, the Elite Max model includes a patent-pending Trail Light off-road lighting feature. With the same emitters found in our popular Stage Series off-road products, the top and bottom reflectors shine extra light in a wide beam, to illuminate the trail ahead.
The high-power LEDs stay cool, thanks to custom-designed heatsinks. An extra switch is included to activate these Trail Lights, or they can be connected to a factory auxiliary switch, if equipped.
Plug-and-Play Installation. These headlights were designed to be a direct replacement for both halogen and LED-equipped Jeeps, in all trim levels. Simply remove your factory headlight assembly and ours will bolt right in its place. A plug-and-play wire harness is included to hook them up to your factory connector, and also add the turn signal connection. No splicing required! With built-in adjusters, the lamps can be aimed using the provided adjustment tool. For Sport owners, a simple add-a-fuse is included to provide the DRL function. Elite Max customers will also receive an extra braided wiring harness, for the off-road and show mode feature! This harness includes a toggle switch, or you can connect it to a factory auxiliary switch, if equipped.
Assembled with Quality - in the USA. Most OEM headlights are made in the US, but nearly all aftermarket headlights are assembled overseas. There’s a reason for that - quality control counts, and the OEMs know it. We’re working to break that mold, and deliver headlights with the same quality you’ll find from the factory. Elite Series headlights are proudly assembled in the USA using OEM-grade materials, including a cast aluminum driver and heatsinks, UV-coated outer lens, aluminum-core circuit boards, and automotive-grade LED emitters. After being assembled by our team in St. Louis, Missouri, they are robotically sealed and individually pressure-tested for long-lasting protection against moisture, before being packaged in custom foam for safe transportation. No expense has been spared, from materials to assembly, right here in America.
Proven Reliability - Backed for 8 Years. Like our popular Stage Series lineup, Elite LED headlights have been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like the factory components on your vehicle. With integrated moisture-proof vents, the lamps can “breathe” with changes in temperature, maintaining a strong seal over time. And with built-in circuit protection for voltage spikes and reverse polarity, these lights will keep working for years. They are backed by an industry-leading 8-year limited warranty.
If you have any questions, we'll be more than happy to help!
Monday-Friday 10 a.m.- 5 p.m. CST
Email: [email protected]
Phone: 314-205-3033
Did you know? All US forum members are eligible for a FREE SHIPPING code! Just send us a direct message.
John C.
Diode Dynamics
SWISTAK
St. Charles, Mo
1995 Wrangler, 2006 Wrangler (deceased), 2023 Wran
Can items be picked up locally? I work across the street from you :)
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
You absolutely can place orders or pickup!
These are only for pre-order at this time but if you're looking at other products in stock you can shop online and select local pickup to swing by our showroom at our headquarters.
You could even just drop by our showroom during open hours to discuss products with staff and take a tour of the facility at no charge if you like!
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
Do you have any nighttime video of these in action? Would really be nice to see an output comparison vs stock to get me off the fence.
Our media team is currently processing additional media for our headlights. I will be updating this thread once that is completed!
silverheep
Fort Collins, CO
2021 JLUR4xe
Any chance these are going to have heating functionality?
After driving through a relatively warm snowstorm yesterday, I was reminded of how bad the JL headlight design packs snow and ice onto the lights, and the factory LED makes that significantly worse with no heat going forward.
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
Unfortunately, these will not include a heated lens.
Most users upgrade their fog lamps to our SS3 Pro or SS3 Max as they're the highest performance fog lamps on the market and melt snow and ice build-up. They are perfect for supplementing low beams in poor weather conditions. Available in a white color output or yellow as seen below.
This image is on an F-150 but it's our SS3 Pro Fog Lights and SS3 Pro Ditch Lights.
silverheep
Fort Collins, CO
2021 JLUR4xe
Thanks for the reply - bummer, as I’d have ordered a heated Diode Dynamics headlight immediately, even at a higher price point, as I trust the product.
I’ve got the SS3 Max in selective yellow, and I’m very happy with them. However, they also were iced over. The snow would pack in and the light would melt out behind the front of the pack, but it wouldn’t cut through until I cleared it out.
That said - I don’t think a fog lamp - even one as good as the SS3 Max - is any sort of replacement for a good headlight beam.
GrayHawk20
Cory
*See Signature for Info*
(Architectural) Jr. Project Coordinator
If you could do some cool sequential tail lights (with Blind spot), I would get front and rear set.
COJeeper
Severance, CO
Jeep Wrangler
Here’s another one for ordering if they had a heating element. I’m waiting for Black Friday specials on the Oracle heated LEDs because it seems like they’re the best in the market currently. I like the off road feature these have though.
blk2doorjl
Troy
Phoenix
2022 JL Two Door
putting aside the heating element, there is no chance the Oracle LED headlights will out perform the Diode Dynamics headlights.
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
We'll be sure to pass this along to our engineering team in the future!
However, this headlamp housing is currently the highest performer on the market even compared to the OEM LED 9" headlamp. We'll have a shootout video on YouTube soon.
Rubitrux
