MarkY3130
I read through them. I plan on using my ball joint tools so I don’t have to uninstall so much crap. Hope there is room for it. Really rather not pull springs and everything. (But will if I have to!)
Same, ill be doing them tomorrow ill report back with how it goes. Also hoping they work on my UD44 pssenger side, the housing is a little differentI read through them. I plan on using my ball joint tools so I don’t have to uninstall so much crap. Hope there is room for it. Really rather not pull springs and everything. (But will if I have to!)
Definitely!I read through them. I plan on using my ball joint tools so I don’t have to uninstall so much crap. Hope there is room for it. Really rather not pull springs and everything. (But will if I have to!)
Mine will be here Tuesday, I plan on using your instructions, so please use small words, and a lot of pics.........Same, ill be doing them tomorrow ill report back with how it goes. Also hoping they work on my UD44 pssenger side, the housing is a little different
Make sure to use lots of 4 letter words as my son enjoys that.Same, ill be doing them tomorrow ill report back with how it goes. Also hoping they work on my UD44 pssenger side, the housing is a little different
I was also thinking or trying my ball joint press too. I'll be watching to see if it works out for you.I read through them. I plan on using my ball joint tools so I don’t have to uninstall so much crap. Hope there is room for it. Really rather not pull springs and everything. (But will if I have to!)
My guess is so you have room to drive out the bushings.I don't understand why they want you to pull the springs?
Limeaide you never should have linked to these as I brought up my RK issues and RockJock was happy to tell me how to solve it
Solve it is best done with their long arm JL setup.....
Looks great! Any disassembly (other than UCA's)?Fully done. Passenger side is a little weird on the UD44 its hollow in the center so it makes lining it up kind of a pain in the ass, no room for the hammer, luckily i was able to use the press and get it in. Took a little trial and error to find pieces that would fit over it and fit in the space, but i got lol. Much better than those garbage rubber bushings.
Not in my case. Might have been a tad easier with track bar moved on passenger side but didnt feel like creating more work. I will say if you have standard springs it will be even more of a pain, it might be right in the way of where the hammer and press go. I was right up against the bumpstop with the press and hammerLooks great! Any disassembly (other than UCA's)?
Good to know, thanks!Not in my case. Might have been a tad easier with track bar moved on passenger side but didnt feel like creating more work. I will say if you have standard springs it will be even more of a pain, it might be right in the way of where the hammer and press go. I was right up against the bumpstop with the press and hammer
Ok, so I need to order coil-overs as an "installation tool" right?Not in my case. Might have been a tad easier with track bar moved on passenger side but didnt feel like creating more work. I will say if you have standard springs it will be even more of a pain, it might be right in the way of where the hammer and press go. I was right up against the bumpstop with the press and hammer
Here's how that would go:Ok, so I need to order coil-overs as an "installation tool" right?
