- Jul 4, 2018
- San Marcos, Ca
- Non-Applicable
Jeep JL/JT, Roof Bar Kits:
It is our pleasure to present the latest addition to our Jeep offerings, the JL/JT roof lighting kits. Our engineers crafted aggressive tig welded 304 Stainless Steel brackets to bring a purpose built aesthetic to your new Jeep built for our 50” S8, 50” OnX6+, or 8 light XL Linkable lighting systems. The brackets are finished in a semi-gloss black powder coat and fit perfectly with our pre-existing JL A-pillar brackets. All kits are available in either Upfitter, or standalone wiring harness versions. Our high performance lighting systems have the style and output that will add value to your rig for many years to come.
Jeep JL/JT, Roof Bar Kit, 8 XL Linkable (PN: 44-7664)
Jeep JL/JT, Roof Bar Kit, 8 XL Linkable w/Upfitter (PN: 44-7664-UP)
Link: https://www.bajadesigns.com/products/Jeep-JL-JT-Roof-Bar-Kits.asp
Setup: Cornering | Combo | Spot | Spot | Spot | Combo | Cornering
Specs: 22,050 lumens, 182 watts, 14 amps
Kit Includes:
(1) 8 XL Linkable lightbar with black rock guards
(2) PS/DS Brackets stainless-steel & powder-coated
(2) Pre-load Support Base, stainless-steel & microtext
(1) 64-0115 Wiring Harness or (1) 64-0094 Upfitter Harness
All necessary hardware
Jeep, JL/JT, Roof Bar Kit, 50" OnX6+ (PN: 44-7666)
Jeep, JL/JT, Roof Bar Kit, 50" OnX6+ w/Upfitter (PN: 44-7666-UP)
Specs: 39,430 lumens, 355 watts, 28.2 amps
Kit Includes:
(1) 50” OnX6+ lightbar
Jeep, JL/JT, Roof Bar Kit, 50" S8 (PN: 44-7665)
Jeep, JL/JT, Roof Bar Kit, 50" S8 w/Upfitter (PN: 44-7665-UP)
Specs: 31,750 lumens, 300 watts, 20 amps
Kit Includes:
(1) 50” S8 lightbar
(1) 64-0122 Wiring Harness or (1) 64-0094 Upfitter Harness
Jeep JL/JT, Rubicon Steel Bumper Kits
Link: https://www.bajadesigns.com/products/Jeep-JL-JT-Rubicon-Steel-Bumper-Kits.asp
Baja Designs has been helping customers mount lights onto the Jeep JL since 2018, thanks in part to the OEM Rubicon Steel Bumpers. The various mounting locations on the bumper make the physical installation a breeze, and after guiding many through this process, we felt it pertinent to provide instructions and a wiring solution to make this a ready-made solution for our customers. Take your pick of some of the best lighting options that exist and add them to your Jeep JL with a streamlined installation process. It has never been easier to have the safest and most effective lighting in the game for your JL/JT.
Note: These kits mount directly to any Jeep JL or JT steel bumper using an existing mount hole. It will not fit any Sport trim models or any plastic front bumper.
Jeep JL/JT, Auxiliary/Light Bar Kits
Link: https://www.bajadesigns.com/products/Jeep-JL-JT-Bumper-Light-Kits.asp
Not all of our customers will have received the OEM Rubicon steel bumper on their JL/JT and will have the plastic Sahara style instead. Rest assured, we have kept you in mind with the following kits. The frame mounted brackets will place either LP4, LP6, or a 30” OnX6+ in the perfect location to illuminate the trail ahead and then some! The powder coated 304 Stainless Steel brackets will withstand the harshest of climates to provide rust free performance for the miles ahead. As with the previous products mentioned, all kits are available with either a standalone harness, or Upfitter wiring solution.
Jeep, JL/JT, Dual LP4 Auxiliary Light Kit (PN: 44-7658)
Jeep, JL/JT, Dual LP4 Auxiliary Light Kit w/Upfitter (PN: 44-7658-UP)
Jeep, JL/JT, Dual LP6 Auxiliary Light Kit (PN: 44-7659)
Jeep, JL/JT, Dual LP6 Auxiliary Light Kit w/Upfitter (PN: 44-7659-UP)
Jeep, JL/JT, 30" OnX6+ Light Bar Kit (PN: 44-7657)
Jeep, JL/JT, 30" OnX6+ Light Bar Kit w/Upfitter (PN: 44-7657-UP)
Note: The 30” OnX6+ Light Bar kits may interfere with some winches.
Jeep JT, S1 Reverse Kit
Link: https://www.bajadesigns.com/products/Jeep-JT-Dual-S1-Reverse-Kits.asp
With the debut of the Jeep JT Gladiator, we were excited to learn that most features were identical to the JL. The only JT specific kit that was needed addressed a common pain point for Jeep enthusiasts; reverse lighting. Our S1 reverse kit replaces the OEM reflectors on each side of the bumper, providing a clean and elegant solution. Installation is a breeze by using existing OEM hardware and either standalone, or Upfitter wiring harnesses. The fitment matches the vehicle so well, it will make you wonder if it came that way from the factory.
Jeep JT Gladiator, Dual S1 Reverse Kit | (PN: 44-7652)
Jeep JT Gladiator, Dual S1 Reverse Kit w/Upfitter | (PN: 44-7652-UP)
Jeep JL, S2 Reverse Kit
Link: https://www.bajadesigns.com/products/Jeep-JL-Reverse-Kits.asp
For the JL, a reverse lighting kit was a must, but we were torn between our new S1 and the tried and true S2 lights. Because this kit was
meant for true trail vehicles, departure angle was our main concern. With that said, the S2 has a shorter overall height and can be
mounted above the bottom surface of the receiver hitch onto existing holes in the bumper. Short of cutting and drilling into your new
bumper for our S2 Flush mount lights, this is the cleanest way to achieve reverse lighting on your Jeep JL.
Jeep JL, Reverse Kit, Dual S2 Sport (PN: 44-7651)
Jeep JL, Reverse Kit, Dual S2 Sport w/Upfitter (PN: 44-7651-UP)
Note: This kit will not work with the sport-line rear bumpers.
Kit Includes:
Kit Includes:
Kit Includes:
(1) 50” S8 lightbar
