New! Adjustable control arms for the JL!
  1. RanchoShocks
    RanchoShocks Well-Known Member
    First Name:
    Vehicle(s):
    2013 JKU
    Oct 16, 2016
    CA
    286
    Liked:
    139
    Rancho® has NEW front, upper and lower Adjustable Control Arms for your stock or lifted Jeep®. The new Arms work on a range from stock to 4.5-inches and the front upper arms allow caster and pinion angle adjustments on the vehicle. This will save time on the alignment rack to allow the setting to be made without having to remove the upper arm. The Arms are made of heavy duty DOM tubing for improved strength to handle off road obstacles. Lower Arms are bent similar to the factory design to allow for larger wheels and tires. The Upper Control Arms feature forged ends using our D2 synthetic high articulation bushings that self-center and are completely grease free.
    Redneck_Jedi likes this.
  2. dannko
    dannko Well-Known Member
    First Name:
    Vehicle(s):
    2018 Rubicon JL Unlimited
    Aug 14, 2018
    Bee Cave TX
    143
    Liked:
    56
    So if I have the Mopar 2 lift kit on my Rubi and need to do caster adjustment, and don't want geometry brackets, then I could just use your upper arms to adjust my caster, correct?
    RanchoShocks likes this.
  3. OP
    RanchoShocks
    First Name:
    Vehicle(s):
    2013 JKU
    Oct 16, 2016
    CA
    286
    Liked:
    139
    Yes sir. A lot go this route. Since if you ever go "bigger" is easy to adjust and easy to adjust on the Jeep. :)
  4. dannko
    First Name:
    Vehicle(s):
    Aug 14, 2018
    Bee Cave TX
    143
    Liked:
    56
    Okay thanks, but what would be best uppers? Lowers? And brackets? What if I only want to do one at this time?
  5. OP
    RanchoShocks
    First Name:
    Vehicle(s):
    2013 JKU
    Oct 16, 2016
    CA
    286
    Liked:
    139
    Uppers at this time or the bracket :)
    Brackets are nice because of the ride is really nice, some say better than stock. :) If you see yourself a lot on the road for a while, go this route.
Loading...
Share This Page
