Nater34
Thanks so much. You have to also get shocks with them as well right? Do you think both would improve the on the road mannerisms equally? I don’t plan on doing any rock crawling and the like.
Haven’t installed but I ordered the Metalcloak 3.5” GC last week. It’s already shipped. It’ll get here before my 392XR does
I was dead set on the Clayton Overland+ kit for a while but was ultimately swayed to Metalcloak due to their bushing design (arguably the best non-Johnny joints in the industry) and their coil spring design. I wanted as much flex as I could get and their joints offer that, they offer more misalignment capability (more flex) than Clayton. Also, they are easily replaceable down the road. Remove the c-clip, use a hammer/socket to remove the joint. I’ve seen videos of people removing their MC joints with 50K miles on them and they came out easily. The Clayton joints will have to be pressed out/pressed in. This is a big deal to me because while both companies market these as “lifetime” joints, if you’re regularly flexing them out and using the lifts for their intended purpose you will likely have to replace bushings at some point (40-50K miles). I prefer bushings that are easily replaceable. Metalcloak has stackable bump stops to fine tune your bump travel, the Clayton kit uses set bumpstops. Finally, I like that MC uses dual rate coil springs to ensure proper spring tension when the axle is fully drooped out.
You will have to get a new front driveshaft with both the MC 2.5 & 3.5” GC kits and the Clayton 3.5” kit. I’m going with Adams 1350s front/rear on my 392XR. Hope this helped! Check out the videos on Metalcloak’s website about their joints and coil spring design.
