Jeepstrangler
I purchased your "JL 4dr: 3.5” Sport ST3 Suspension System & Falcon SP2 3.1 Piggyback" and have had a plaguing noise since install. The sound is a creaking noise coming from some where in the suspension, when braking or suspension flex. I contacted Teraflex support after discovering the aluminum spacers that are put in place for the Front Control Arm Sport Brackets, were to short. Despite torquing to spec, they with were still loose and moved side to side. New spacers were sent out (thank you) reinstalled and were finally tight. But despite this the creaking noise remained, although it did not happen as often. I have rechecked all torque specs and gone over the entire install, but I can not figure out this noise.
Im curious if anyone else who has this installed is having the same issue.
