NEED HELP - (sorry) - Replaced dead battery in the jeep and then replaced the aux battery. Now I have no response to pushing the start button....
mattm73
Gainesville GA
2019 Sahara
small screen comes on and asks you to push the pedal and then nothing happens.....
Im at a total loss. Even put the older - questionable but charge AUX battery back in and got same result.....
Sorry I am sure i have something super basic wrong and i need to get it rolling pretty quick.
mattm73
Gainesville GA
2019 Sahara
FYI - Jeep is brand new to me and just out of warranty.
aldo98229
Aldo
Bellingham, WA
Market Research
Sounds like something is not properly connected.
Check the battery terminals, and also the bottom of the fuse box.
Good luck.
mattm73
Gainesville GA
2019 Sahara
Good luck.
Thank you! The first instructional video did not discuss taking precautions because the fuse bar an battery leads would still be hot.....i didnt see any arcing but what if i shorted it - any idea what relay or breaker to check?
mattm73
Gainesville GA
2019 Sahara
what specifically do you mean about the bottom of the fuse box?
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
Some people remove the fuse box to change the aux battery. If you went that route, it's possible that a pin, or perhaps pins, ended up bent and therefore not mating with the connector causing your problem.
And what exactly is "no response"? Does the switch light up at all, or is it just not cranking?
mattm73
Gainesville GA
2019 Sahara
I will check them thoroughly thank you!!!! My bet is this is it.....
aldo98229
Aldo
Bellingham, WA
Market Research
^ this!
Also, I found it difficult to push the fuse box connectors all the way in. My hands are too big to do it properly in that cramped space.
If you ran into this problem, it is possible that one of the connectors is not tight enough.
Good luck.
27352
Illinois
99tj 21 2dr willys sport, 22 4dr willys sport XR
Just happened to watch this morning. Maybe it might help you if you did accidently short one of the connections?
Austin23
Michael
Austin, TX
2020 Jeep Wrangler Rubicon
Wandering a bit off topic here, but watching videos of both methods, it appears to me that pulling the passenger side fender flare is the much easier route to accessing the aux battery. Messing with all those fuses looks a bit sketchy.
aldo98229
Aldo
Bellingham, WA
Market Research
Wandering a bit off topic here, but watching videos of both methods, it appears to me that pulling the passenger side fender flare is the much easy route to accessing the aux battery. Messing with all those fuses looks a bit sketchy.
Depends how OCD you are, I suppose.
I feel much more comfortable screwing around with a hidden fuse box than pulling apart a body section.
I played around with the fenders on my JKs over the years; it was impossible to get them to look —and feel— just like they came from the factory. No matter how much I tried.
I now know that if for some reason I cannot put this fender back EXACTLY the way it came from the factory, it’d drive me insane...!
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Average Joe has no business whatsoever pulling the fuse box. If OP went that route and can’t diagnose a no start afterwards, it’s gonna be a bad day.
mattm73
Gainesville GA
2019 Sahara
I did go that route. THat darn youtube video made it look easy. Never had an issue with other dual battery trucks either, and my boat has two batteries..... ugh.
Regretting this.
mattm73
Gainesville GA
2019 Sahara
One other thought- how do you tell if one of your fuses is blown on that high voltage buss bar? I have not encountered this arrangement before. that whole buss is one unit.
mattm73
Gainesville GA
2019 Sahara
The dash text reads - "push in the clutch and push start", but the button will not light up. Press it and nothing happens. No NAV screen lighting up either....
