oceanblue2019
These steering boxes are supposed to be all bench adjusted. They have this test bench that connects to the input shaft and the pitman shaft and measures "system lash" while someone adjusts the hex screw to get it into tolerance. They then tighten the outer nut to lock it and mark it. I've seen this process during a factory tour and paid attention to it as related to what I do for my career.Hi Word302,
Adjusting this set screw for a mechanically inclined individual who understands jam nuts, adjusters, creep, lash etc...was very easy. I could tell by feel alone that there was absolutely NO contact with the set screw internally and the gears, I made three extremely small incremental clockwise adjustments then backed off a little. This was all checked at full lock left, full lock right and steering wheel centered. The results are remarkable. The "return to center" is now as good as any new Jeep will be. The looseness felt and constant corrections to keep this Rubicon safely between the lines on the road are at a minimum now, in fact I could definitely snug it up a little more without issue but it is SO MUCH better now that I'm pleasantly surprised and happy.
I do NOT suggest that those who are not mechanically inclined to attempt this.
What I did arrive at is that the loose steering issue is absolutely related to improperly adjusted steering boxes, even in "AE" boxes in brand new 2020 Jeeps....and that is precisely why we called out Mike Manley
I suspect that either the test bench(s) went out of calibration and caused a bunch of badly adjusted boxes, or some got through without this process, or some improperly trained workers.
At the end of the day we get this sh!t in our vehicles, along with steering stabilizers that are defective, badly torqued tie rod ends, crappy track bars, and bad welds - and who knows what else awaits.
In typical corporate fashion as not enough people have died because of this (Boeing 737-Max as a reference) and therefore no real pressure to solve it quickly or properly they are messing around, starting with the cheapest components and hoping doing something keeps the NTSB and class actions stalled as "it's being solved!"
Perhaps the NTSB should order a stop-sales like the EPA did with the Audi dirty diesels to force FCA to do the right thing.
I've been told a new version of the steering box was coming that had some sort of automatic lash adjustment. But that was supposed to be the AE which is clearly not the case.
Will we ever see a proper fix for 2018 - 202x models? Who knows? I am of the mindset that some major re-design in the steering will happen sometime in a future model and those who bought before are left to live with what we have.
