Padre
- Paul
- Jul 2, 2024
- Limon, Colorado
- 2021 JLUR
So the rig I bought used had Toyo Open Country Rough Country 35x12.5's on Method 309's (0mm offset, non-beadgrip) on a Mopar lift. Tread was at about 50%, but I got some good use from them in Moab and Colorado.
However, I don't like the aggressive poke (more than 2", I was kicking up rocks onto the body), plus I wanted some 3-peak tires for Colorado, since I'll be living high and deep in the mountains by the time the snows start. Also, narrower tires do have advantages offroad and in the snow and rain, and lighter weight should help fuel economy and road manners. This is my daily driver.
So after a lot of searching, I settled on:
- Method 703's, 17x8.5 with a +25mm offset ("Beadgrip" technology from Method)
- Falken Wildpeak A/T4W's 35 X 11.50 R17 (LT 118R C1), 3-peak rated
Now, the tires are tucked in much better, with the treads inside the stock fenders and just a little sidewall sticking out. The +25mm brought the setup in one inch, but the narrower tires mean I'm maybe only a half inch closer to the struts, etc.
Pros: At 10+ pounds less per corner, I expect better economy and road manners. Initial drive, it seems more nimble and responsive, less floaty. Bigger test will be on the highways and on the plains, where the old setup exaggerated bumps and grooves in the road. I loved the Wildpeak 3W's on my Trailhawk, so I look forward to these 4W's.
Cons: the old 309's had a ring that protected the stem and spokes (no worries when on rough trails in Moab). The new 703's have no ring and less lip, so I'll have to me more careful and expect they'll scratch more easily.
Anyway, here are the pics. I'm very happy with the setup. Special thanks to Brennan at CORE Off Road in Castle Rock for the consult and getting me set up.
