CarbonSteel
I have a set of ISS Pro temperature gauges (made specifically for the front and rear axles) that I will be installing soon. In order to do that I needed to weld in a 1/8” NPT boss into the tops of the covers (I am using OEM covers as rock crawling is not in my future). After studying several videos of oil splash patterns inside axles in operation, I selected a location near the center of the ring gear as it will push the vast majority of oil to the top and slightly left of the centerline and will keep the temperature sensor well covered in oil.
Since the majority of axle wear occurs at 15K miles or less, I plan to dump the oil at 5K (and clean out the housing while switching covers) and I will probably dump it again at 15K and call if good until 65K. Amsoil severe gear will be going into both axles as I have had excellent results with it towing heavy with my (now retired) Ford trucks.
I have to give a shout out to @rustyshakelford for graciously giving his time and resources on this endeavor—he donated the OEM covers, welded the threaded bosses into them, and brought the covers with some of his items to be powder coated (at a great price). A very stand-up guy (a true rarity these days) and I would highly recommend anyone in the Texas area needing lift/suspension alterations/upgrades to give him a shout.
Many thanks @rustyshakelford for everything!
I will post updates to this thread as I move along.
