Not sure if you are coming or going...
I bought two 7.5' Warn cables with quick disconnects on the end of each one. One is attached to the winch and the other one is attached to the battery. With this setup I can easily reach the back or front.I am considering a similar set up. Could you provide details of how you ran the power connections?
It is, I installed it yesterday. Very good quality and easy to install. I also bought the Curt winch plate. It has a miniature skid plate welded on the bottom of it. I thought that was kinda cool.that is a good way to do it. As I have a 4 door I am concerned that might not be enough cable. Looks like I need to do some measuring. Do you have the curt receiver mount in the front?
Its one and the same Winch.is that two separate winches or one that you swap from front to back?
And if one where are you mounting it?
