WTFSoCal
- John
- Jul 24, 2018
- Mission Viejo, CA
- Website
- www.youtube.com
- JLU 2018 Rubicon
- Occupation
- Network/Systems Engineer
Im willing to bet that you shorted the positive battery cable on the to engine someplace and it blew one of the main fuses on the main array on the PDC. Im not sure of the correct terminal you need to look at, but you can run a continuity test to determine which of these fuse(s) popped when you shorted the battery cable.So as of now nothing I’ve done works. On the brightside I’m loving the music system. I just like to hop in playing music and cry cause it won’t Fu***** start 🥲. Apparently the batteries are good, I only snipped old speaker wire cables and all the connections are solid. I have a tow truck coming to slide it out of my garage and take it to the dealership near by. Also the fuses I could test were all good to go, I have no idea what it could be.
Im referring to the area surrounded in yellow in this picture...
https://www.jlwranglerforums.com/JL-Wiring-Diagrams/POWER-DISTRIBUTION-CENTER-LAYOUT.pdf
In that diagram, look at the legend (right side toward the bottom for several high amp fuses, 300,150,125,60 amps... those are the ones you need to check... you will have to disconnect BOTH batteries and replace it if your continuity check fails.
I have a spare one of these just in case...
Check this thread for that.. and be aware there are two different fuses, depending on if you have the tow package or not...
https://www.jlwranglerforums.com/forum/threads/internal-fuses-in-the-pdc.15456/
