My Jeep hates me.
Sean L
Sean
North Carolina
Hope your oil isn't jello at that temp. :surprised:
Paluss
maryland
2022 JLURD
starting is not an issue as long as the battery is fresh, the issue with cold weather starts is the time it takes the oil to flow to parts that need constant lubrication, the slower the flow of oil increases chances of wear. But what I'm reading these days it better to drive the vehicle after starting to warm it versus letting it idle for 10 minutes....
KarlG
Karl
Central NY
2012 AEV 350 JK Rubicon 2019 JLUR
I run full synthetic so it shouldnt be.
I run full synthetic in all my vehicles as well but for the cold the most important factor is the low temp viscosity (the number before the "W"). 5W20 is better than 10Wx at lower temps.
ImAJeepskate
ImAJeepskate
Grant
Minnesota
2018 Jeep Wrangler Unlimited Sport (JLU)
Always 5w30 for me
EZMFE
UT
I'm thinking maybe a heat lamp under the oil pan as a temp solution. Could also do a blanket over the engine compartment to keep any heat in. I don't think it would take that long to warm the oil up a bit.
danotje
Alaska
I got a block heater from the dealer and did the install at home. It’s quite a bit of tear down, but ultimately not too hard. I also installed two heat pads—one on the oil pan and one on the transmission. All three run to one plug at the front. The pads were easier to install with RTV, but I always feel the block heater is better. Also change the coolant and think I’m running 0W20. This worked for our Grand last winter and seems to be holding up with the JL, too. We’re having long stretches of —40 here in AK, but so far, no issues. $100 and about 2 hours, and you should have a block heater in.
Capricorn
Las Vegas, NV
2024 JL Willys XR V6
Network Architect & Engineer
Jeep Wrangler JL My Jeep hates me. 4B4F9623-728A-4B1D-B6B1-604B7C68688F
I definitely should have gone with the engine block heater. Nothing like -26F cold starts for the work commute. Im sure im getting plenty of wear on my rings...
If you keep it in the garage, I suggest you get a portable heater and run it for a couple of hours to warm the garage up a little. Like a Vornado or a ceramic space heater. An old fashioned method is to keep a 100W or 150W lamp under the Jeep below the engine.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Man, what do you guys do when it gets cold? Lol. I haven't even plugged mine in this winter. We have had some days that cold with wind chill. Shootz the rental Corolla I have started in -32C this morning.
I'm kidding, that's cold. But I haven't used my block heater yet. I don't want to make my jeep weak. ;)
