2018JLRUSellersremorse
Jus very little for quiet but a lot coolerI saw where hot head liners offer a insulated pad that doesn’t affect the top and makes it quieter and cooler
We had them on our last Jeep and they were more than fineIn case you don’t know, the “step assist” are definitely just “assist” , very narrow, if she needs running boards /a true step they barely qualify.
I’d have to respectfully disagree with this comment. There have been LOTS of known problems with steering on Wranglers since the JL was released (TSB for PCM flash, steering box problems, death wobble, dead spot in center, steering components not torqued to spec, etc.). There are also lots of threads on this topic on this website.i hated the steering the first week as well. It’s not because it’s loose or not precise, it’s because it doesn’t naturally return to center like IFS vehicles. I eventually discovered it’s not really the jeep, it was me needing to adapt to it mentally and not just expecting it to go straight on its own. It took me about 1500 miles until I didn’t notice it at all. That’s why other jeep owners generally don’t say much about it. They all just adapted to it.
we both have rubi 4xe’s with the updated steering box, we both had the same initial perception of the steeringI’d have to respectfully disagree with this comment. There have been LOTS of known problems with steering on Wranglers since the JL was released (TSB for PCM flash, steering box problems, death wobble, dead spot in center, steering components not torqued to spec, etc.). There are also lots of threads on this topic on this website.
I’ve driven three JLs - one had awful steering, and two had perfectly acceptable steering. I can’t tell you how many posts you will read on this site that say: “It’s a Jeep thing. Get used to it.”, or “It has solid axles and no IFS, what do you expect?”, or “You don’t actually WANT tight steering on an off-road vehicle.” Just because it has solid axles and no IFS does NOT mean your particular Jeep does not actually have a problem.
For the OP @pantheman75 I’d suggest you do some reading, reduce your tire pressure, test drive some other JLs, then decide if it’s ’a Jeep thing’, or if it’s ‘a thing with YOUR Jeep’
Here’s a post where I summarized the steps I took to correct steering issues on one of my JLs: https://www.jlwranglerforums.com/forum/threads/loose-steering-on-the-4xe.72215/post-1507528
Weird looking charging station.
I'm also very impressed with the transition between ICE and electric, you almost can't tell.The OP reports transitions from electric to ICE are smooth. That's great because when the 4Xe was introduced Car & Driver wrote the transitions were awful. I will give the benefit of the doubt to the OP and FCA and opine the software must have been massively improved.
It's more planted on the road. I didn't notice any difference in range. I also didn't regear. I got the lift and the odometer tire size adjustment at the dealer, and they said there is no need to regear with 35s.@unknownsolo how different is your 4Xe since going to 35's?. Did you regear? It looks tough.
I noticed the AEV 35" package does not regear. They also use a 2" spacer lift along with their geometry brackets. Their use of a spacer lift has got me thinking if the benefit of a spring lift is mainly in the replacement shocks. It's probably theoretical in my case as I feel my Rubi is already high enough off the pavement.It's more planted on the road. I didn't notice any difference in range. I also didn't regear. I got the lift and the odometer tire size adjustment at the dealer, and they said there is no need to regear with 35s.
They will over inflate your tires at the dealer also, I'm sure it is for fuel mileage numbers.Here are my initial thoughts in no particular order:
- I live in a very hilly area, and it's no surprise the those hills absolutely kill the all electric range. It's still just enough for me to get to / from work without using gas, so I'm happy.
- I know people will disagree with this, but it's my opinion that adaptive cruise control is a MUST considering the "drag" of the regen / max regen brakes. It makes for a MUCH nicer and relaxing driving experience.
- A level 2 charger is a must. Sure, it will charge overnight using the included charger, but 12-13 hours to fully charge limits the usefulness of the electric range feature.
- The steering is sloppy and disconnected. You really need to be playing attention to what you're doing at higer speeds.
- The cloth seats are much more comfortable than the leather ones, not to mention they're warmer in the winter, cooler in the summer, and save you nearly $2K. (I'd actually pay $2K NOT to have the leather interior LOL.)
- I'm completely SHOCKED (no pun intended ) how smoothly the vehicle shifts between electric and ICE usage. I pretty much need to watch the RPM needle to know when it happens.
- This is a high vehicle. It's rediculous that the Rubicon doesn't offer a factory running board or rock rail with step option like some of the other models. I'll be swapping my standard rock rails for the MOPAR performance ones with a step to assist my 5'2" wife
- The Sky One Touch roof is an obscene amount of money, but is totally worth every cent. Yes, it's a little louder than a hardtop inside the vehicle, but I would describe it as "plenty quiet". At highway speeds you can easily hold normal conversations with passengers without raising your voice. The downside is not being able to use automatic washers, but spraying it off manually isn't a big deal for me where I live.
- Currently I'd say I love everything but the steering. I know my tires might be a little overinflated from the factory so I'm going to start there trying to correct it.
