Moved the backup camera on an 18 JL
Sand Flea
Sand Flea
Lewes DE
2018 JL Wrangler Unlimited, Sahara
Federal Firefighter, Retired
BTW, how do u mount your surf rods to the bike mount??
the bike rack is used to carry sand chairs and umbrellas for beach duty.
Surf rods go in a rod rack that attaches to the front receiver hitch.
KGriner
K.
PHX
2019 Rubicon
somewhat, but is not the best. I don't rely on it at all, just the old fashioned way of turning around and looking!
Sweet thanks!
l’ve got the same bike carrier as you, got it new for $140. Well worth cutting the tire carrier IMHO
I’m working on a mount for the camera now, looks like it may work. The one pictured is a prototype the new one is similar but with a longer & angled neck to get the cam out past the rim.
I could use the one pictured, if I can figure out how to epoxy the OEM plastic cam mount tube to this sheet metal. That oem tube has the perfect downward angle so if I attach it to the mount in the pic, it would work great. But attaching metal to plastic , not easy...I’m looking for the right epoxy.
Hope to have a solution tomorrow, will post when finished.
Thanks for the info!
KGriner
K.
PHX
2019 Rubicon
Hoping this holds, Are used a JB Weld Epoxy that’s especially for bonding plastic to metal.
Testing it now to see if paint will stick to the epoxy, Going to paint this going to paint this a metallic gray to blend in with the stock wheels before I put it on the car.
If it works, this will be the final solution for me... If not I’ll keep the long angulated metal version.
four low
central New York
2018 JL
I have a Mopar Freedom Panel carrier from my JK, it has the same mounting plate set up. Making a mounting plate for the rear camera so it can be moved to more than one location is a great idea !
KGriner
K.
PHX
2019 Rubicon
Great, have u started yet?
KGriner
K.
PHX
2019 Rubicon
It’s done!
The epoxy feels rock solid, the view is unobstructed, like OEM.
I’ll put all the steps in a separate Posting here as a DIY
TRZ
Tom
Denver, Colorado
2019 JLUR, Ocean Blue
It’s done!
Thanks for the idea! I need to move my license plate into this are due to an aftermarket bumper, I may use this strategy to move the camera and add fasteners for my license plate.
KGriner
K.
PHX
2019 Rubicon
good luck to you, hope the pics help.
Sand Flea
Sand Flea
Lewes DE
Nice fabrication. Looks good.
DanNH
New Hampshire
2019 Jeep Wrangler Rubicon
Nice! I did some mods to my Thule to make it work. Hated that I had it sitting in the garage collecting dust and was too cheap to just buy a new rack!
Don't know that it would work with the upgraded Sahara wheels though.
Jeep Wrangler JL Moved the backup camera on an 18 JL 61699A33-2620-4CCC-B834-57229BCD5B2C
Yours is an old post now. I have this same Thule bike rack and I LOVE your mounting solution!! Can you post the details of what you did/fabricated/changed to move the Thule mounting plate please? Thanks so much in advance!
TheJoyceIsYours
Brendan
St. Joseph, MI
www.lbdesignworks.com
2018 JLU Sahara
Designer
Thank you! I actually did a decent write up with the details and a template...
https://www.jlwranglerforums.com/fo...-bike-rack-relocation-bracket-template.35071/
Let me know if you have any questions on it. It seems to have held up for 2 years so far!
DanNH
New Hampshire
DanNH
New Hampshire
No Problem! You could probably do it just fine with a jug saw and metal blade. I bought some cheap step bits from Amazon that helped quite a bit with the various holes.
Good luck!
Great thanks a lot!
