Motobilt tire carrier hinge gap fix
Hydroboy35th
Josh
Zanesfield Ohio
2018 JLR
Hello, I searched for this and didn’t see anything so I thought I’d add this for anyone else that wants an idea.
The Problem:
The Motobilt spare tire carrier replaces your factory hinges and leaves massive gaps to the body around the new hinge.
The Fix:
To remedy the problem I used expanding foam tape. The tape expands to 1 inch and closes the gap, it’s not 100% waterproof but it should help a lot with keeping water out during the rain and when it gets a bath. It only takes one layer around the hinge hole to close the gap.
Jeep Wrangler JL Motobilt tire carrier hinge gap fix F2EC728C-C18A-4E37-953A-A07A6EE5C976
Jeep Wrangler JL Motobilt tire carrier hinge gap fix 9C2A8A22-A66A-4299-917E-44836E2A5EF0
Jeep Wrangler JL Motobilt tire carrier hinge gap fix C1471F08-5A99-4B22-9532-A75DDF2CF249
Jeep Wrangler JL Motobilt tire carrier hinge gap fix 630D1ADA-CF02-4D74-80A2-B5A131AE3746
Jeep Wrangler JL Motobilt tire carrier hinge gap fix 87516BE0-E5A2-4D9B-9F99-F5BA4EDD9EEF
ShafferNY
Ticonderoga, NY
2016 Willy's JK, 2019 Rubicon JL
Thank you for sharing! I've been looking for a solution to this on the factory hinges. FCA should house addressed this!
TJP
PA USA
20 JLU Rubicon
Looks good. Did you paint the carrier yourself? How do you like it?
spurly
Zach
Nebraska
2019 Bright White JLUR
I'm planning on getting the Motobilt tire carrier but this does leave me with some concerns.
Living in the midwest where we really like to season our roads in the winter, I feel like this is a major entry point for salt, dust, and mud. I'm sure there's some reason behind the gap to allow for any body twist but it seems a bit larger than necessary. I wonder if @Motobilt could make a cover plate with a rubber/foam gasket to keep it clean.
spurly
Zach
Nebraska
Bump.
Wanting to bring this back to the top to see if anyone else has any ideas or other solutions.
TJP
PA USA
20 JLU Rubicon
Bump.
Spurly,
I think if you’re worried about rust, you may want to consider another carrier.
I had same worry and went w the Rustys which is e coated and powder coated. E coating is dipped, so it gets the insides.
Rusty’s is also ridiculously overbuilt. I hung a 37” on it and you wouldn’t know the tire was there. There’s a slight gap (not as bad as the mb) but I’m going to use that foam tape... just have to get it.
attached pics so you can see all the reinforcements etc.... they are releasing shovel and ax mount, gas and water can carrier and have a jack mount now.
spurly
Zach
Nebraska
Spurly,
I'm not so worried about the tire carrier itself rusting, but more so about water and salt getting in through the gap between the body and hinge. I don't have my Jeep with me right now so I can't see how it's covered/protected from the factory, but we really like to season our roads here in Nebraska. What's the gap look like on the Rusty's?
Hydroboy35th
Hydroboy35th
Josh
Zanesfield Ohio
2018 JLR
Sorry for the late reply but yes I did paint it my self using “Steel-it” black. That stuff is awesome it lays really nice and it also blends really nice. I like the tire carrier itself but if I had to do it over again I’d go with the Maximus-3 carrier. It has heavy duty hinges and the carrier itself is lighter.
Jeep Wrangler JL Motobilt tire carrier hinge gap fix 1F16D911-3235-47EA-A9E5-AA7AE721BEDB
Jeep Wrangler JL Motobilt tire carrier hinge gap fix FCBCCF31-BA10-4B2B-BB76-DD5F4F285C9F
Hydroboy35th
Hydroboy35th
Josh
Zanesfield Ohio
2018 JLR
@spurly check out the Maximus-3 carrier. If I had it to do over again that’s the one I’d go with. I really like my motobilt one but the Maximus-3 seems to be better engineered.
conFUcius
Stephen
North Carolina
2020 Sting-Gray JLU Rubicon 3.6 V6
Medical Affairs
After running the MB tire carrier almost six months now, would you still recommend the Maximus-3 over the MB tire carrier? Definitely like MB’s products (have a few already) including their license plate + camera bracket. I was planning on running this with the Mopar set up but am contemplating switching set-up to the MB one since my rear sensors are turned off (they come on because of the 37” tire).
Zotch
NJ
2020 Hella Sport S JL
Nice job with the tape.
Looks like a poor design from MB
David P.
Durham NC
2021 JLUR
Bump - does anyone have a picture of their Rusty’s tire carrier or CavFab tire carrier with the door open, to show what kind of gap there is?
mvidor
Calvin
Beaumont, Texas
JLU Rubicon
The Problem:
The Fix:
Bump.
I used some 1/4 inch rubber glued on with 3M gasket glue. Below are some pictures.
Jeep Wrangler JL Motobilt tire carrier hinge gap fix 258EA9EF-EF40-4BE0-A29F-CB25E3E8E5D4
Jeep Wrangler JL Motobilt tire carrier hinge gap fix D948E238-5C71-45DB-BF37-87C58442612A
