Motobilt Rear Crusher Bumper w/Light Cut Outs
4xnaz
Tim
Phoenix, AZ
www.instagram.com
2018 JLU Rubicon
Installing soon but off to get coated first. Motobilt Rear Crusher Bumper with 3x3 light pod cut outs and Spare Tire Tag Relocation Kit and Camera Mount.
4xnaz
4xnaz
Tim
Phoenix, AZ
www.instagram.com
2018 JLU Rubicon
Finished the install. Cerakote finish with the addition of Riged Industries Midnight Edition D2 cubes. I ran the wire through the passenger side frame rail and up into the engine bay to the pre-wired auxiliary switch. The rear camera use at night is way better and the before/after pic shows it.
WhyUMad
Ryan
New Orleans, LA
Mechanical Engineer
Looks great! I’m going with this setup without the led pod cutouts. Was it pretty much direct bolt-on?
4xnaz
4xnaz
Tim
Phoenix, AZ
www.instagram.com
2018 JLU Rubicon
Couldnt be any easier! Only 8 bolts total, 4 on each side in the factory OEM holes.
Install tip when doing it alone: keep the tailgate OPEN during the install. :)
WhyUMad
Ryan
New Orleans, LA
Mechanical Engineer
Awesome & thanks for the tip!
Signu616
Houston
2019 Jeep Wrangler MOAB
Could you please share with me what tire carrier / reinforcement bracket you are using?
4xnaz
4xnaz
Tim
Phoenix, AZ
www.instagram.com
2018 JLU Rubicon
Sure. I'm using the Mopar Oversize Spare Tire relocation kit with the Mopar reinforced tailgate hinge.
ericpascual
Eric
Prince Rupert
2019 Jeep Wrangler unlimited rubicon
Do you have an install video for the led pods? Are they 3 inches?
4xnaz
4xnaz
Tim
Phoenix, AZ
www.instagram.com
2018 JLU Rubicon
No video, I'm sorry but its very simple. 3x3 pods using a surface mount. They will hang upside down on the inside of the Motobilt bumper. I grounded at the tow hitch and fished the power wire, with a metal coat hanger, through the inside of the passenger frame rail, up into the engine bay and over to the pre-wired bundle for the Aux Switches by the battery.
ericpascual
Eric
Prince Rupert
Did you use any wire loom to protect the wire from the outside elements?
ericpascual
Eric
Prince Rupert
What powder coat finish did you go with regular textured black or satin black?
Cptbigdog
Eddie
Bakersfield
Jl Rubicon
Did you go with this spot version/ pattern light of the rigid lights
Rubitrux
