RebelOffRoad
- Evan
- Jul 28, 2016
- Website
- www.rebeloffroad.com
- 2018 Jeep Wrangler JLU / Jeep Wrangler Rubicon 392
- Occupation
- Jeep Builder
Rebels Deal Of The Week - Includes Free Shipping
Motobilt introduces the Jeep JL 2018 + spare tire carrier. This heavy duty tire carrier is a must have if you are running larger tires on your Jeep. The stock setup is not equipped to handle the extra weight of a larger tire and wheel setup. Our design takes all of the stress off of the factory tail gate and transfers it to our heavy duty steel carrier. The new JL tire carrier was designed using cutting edge computer modeling software. We laser cut, cnc form, and hand weld each unit to ensure it is perfect. We also engineered it to install easily with basic hand tools.
View Tire Carrier Here: https://jeep.rebeloffroad.com/product-p/mb1089.htm
Receive Free OFFROAD ONLY LITEDOT PLATE LIGHT WITH 6 FOOT DISCONNECTABLE HARNESS with purchase of tire carrier!
Features:
- 3/16 inch laser cut and cnc formed steel
- CAD designed for perfect fit
- Will hold up to a 40 inch tire and high lift jack together if equipped.
- 12 mounting points vs the factory 4 mounting points
- Multiple adjustments both vertically and front to back for optimal tire position.
- Same wheel lug size and thread as stock sizes
- License plate relocation kit MB2115 works perfectly with the mount.
- Integrated design allows you to open and close easily with factory door handle.
- Will work with factory bumper or aftermarket bumpers.
- Greasable mounting bolts at pivot points on hinges
- High density hinge bushings with steel inner liners
- Includes necessary mounting hardware.
- Includes hardware
Benefits:
- Easy to open and close
- Easy to bolt on Motobilt accessories
- Increased load capacity.
- Adjustable tire position allows clearance for up to a 40 inch tire.
- Ships bare metal and will need to be painted or powder coated.
- Factory tailgate catch must be removed.
Motobilt offers: Off Road Only LiteDOT Plate Light with 6 foot disconnect able harness. This is a LiteDOT Plate Light with a six foot disconnectable harness and solder seal connectors for splicing into the wiring harness.
The LiteDOT Plate Light's rugged design is completely sealed, vibration and water proof. It is ideal for an off road vehicle, trailer, motor home or any other rugged use vehicle, such as a dump truck.
It mounts on any license plate with mounting holes 7" on center. The stainless steel bracket mounts directly behind the license plate. The polycarbonate housing extends out over the edge about two inches.
Ultra-bright white LED's are used to illuminate the license plate. The housing also has three rear facing red LED's that can be wired as a third brake light when the license plate is mounted in the center of the vehicle.
The wiring harness on this version is designed for use with the Motobilt Tag delete kits . MB1044-P, MB1047P, MB2025, and MB1077 which positions the LiteDOT Plate Light in the center of the spare tire. The six foot harness features a connector for easy disconnection when removing the spare tire.
