Motobilt
- Bobby
- Jun 11, 2018
- Dothan, AL
- 2018 JL Rubicon
Motobilt introduces the Jeep JL 2018 + spare tire carrier. This heavy duty tire carrier is a must have if you are running larger tires on your Jeep. The stock setup is not equipped to handle the extra weight of a larger tire and wheel setup. Our design takes all of the stress off of the factory tail gate and transfers it to our heavy duty steel carrier. The new JL tire carrier was designed using cutting edge computer modeling software. We laser cut, cnc form, and hand weld each unit to ensure it is perfect. We also engineered it to install easily with basic hand tools.
Features:
- 3/16 inch laser cut and cnc formed steel
- CAD designed for perfect fit
- Will hold up to a 40 inch tire and high lift jack together if equipped.
- 12 mounting points vs the factory 4 mounting points
- Multiple adjustments both vertically and front to back for optimal tire position.
- Same wheel lug size and thread as stock sizes
- License plate relocation kit MB2115 works perfectly with the mount.
- Integrated design allows you to open and close easily with factory door handle.
- Will work with factory bumper or aftermarket bumpers.
- Greasable mounting bolts at pivot points on hinges
- High density hinge bushings with steel inner liners
- Includes necessary mounting hardware.
- Includes hardware
Easy to open and close
Easy to bolt on Motobilt accessories
Increased load capacity.
Adjustable tire position allows clearance for up to a 40 inch tire.
Notes:
- Ships bare metal and will need to be painted or powder coated.
- Factory tailgate catch must be removed.
https://www.motobilt.com/sites/default/files/MB1089 Assembly.pdf
ORDER HERE
YouTube Video: Jeep JL Spare Tire Carrier Installation From LiteBrite Studios
Click Here To See More
Click Here For Install Instructions.
Testing
