MOTOBILT JEEP JL SPARE TIRE TAG RELOCATION KIT WITH CAMERA MOUNT
Status
Not open for further replies.
Motobilt
Bobby
Dothan, AL
2018 JL Rubicon
The Motobilt Jeep JL Spare Tire Relocation Bracket Kit With Camera Mount is used to relocate your license plate and back up camera to the center of your spare tire. The Jeep JL factory tag mount is located on the bumper and is subject to damange and has to be relocated if your running an aftermarket bumper. The kit is laser cut from 1/8" steel and consists of 3 main pieces. The first part slips over the studs on your tire carrier with the spare tire removed. Then place your spare tire back on and secure the lug nuts holding the inner bracket in place. Next simply attach the outer part of the tag relocation bracket with the one bolt provided in the kit. The outer bracket is slotted so you can adjust for different wheel widths. The third piece is the camera mount which mounts underneath the tag. We changed the angle of the mount so that your view from the camera is unchanged from the factory. The bracket kit ships bare metal. You can simply spray paint with a rattle can to the color of your choice or have it powdercoated.
Features:
  • Jeep JL Spare Tire Tag Relocation Bracket Kit With Camera Mount
  • Includes mount for factory back up camera.
  • CNC cut from 1/8" high strength steel plate
  • Adjustable for different size wheels and off sets.
  • Sold as kit
Note:
  • Ships bare metal. Paint or powdercoat the color of your choice
  • Third brake light/tag light kit package available. Use the drop down menu under "Select Product" Most states require a tag light!
ORDER HERE
Motobilt
Motobilt
Bobby
Dothan, AL
2018 JL Rubicon
The all new Motobilt Jeep JL Spare Tire Tag Relocation Kit With Camera Mount is super simple to remove when accessing your spare tire. The mount was designed to move the license plate from the rear bumper up into the middle of the tire and provide a new mount for the back up camera. By doing this you move the license plate out of the low vulnerable section of your factory bumper. We also wanted it to be super simple to take on and off in case you need to use your spare. So be sure to check out this video show casing how simple it is to remove the Motobilt Jeep JL Spare Tire Tag Relocation Kit With Camera Mount.
Status
Diode Dynamics
