More narrow 35in tires
Mojito Mojo
Doug
Apache Junction, AZ and North Mankato, MN
2018 Mojito Rubicon JLU, 2004 Corvette convertible, 2015 HD Road Glide, 2014 Indian Chief Vintage
Ahre
Paul
Livermore, CA
2020 JLUR, Ordered Mar 14, 2020
Hopefully you guys are telling Nitto per the kink I provided! It’s the only way they’ll make em.
I just requested LT295/80 R17 Ridge Grappler (35.6" x 11.6" x 17" Rim)
Taxman
Alex
Raleigh, NC
1985 CJ-7, 2018 JLUR
CPA
Just ordered a set of five Toyo A/T III (M/S) in the 35x11.50R17 flavor. Factory specs allow for mounting on a 17x7.5” wheel, so I will keep my stock Rubicon wheels. Got them for $265/each on Simpletire.com. Found a local shop to mount and balance for $100.
Also ordered a 1.5/1.0 suspension spacer set from Traxda.
I’ll post photos when finished.
LooselyHeldPlans
Brandon
Denver
2020 3.6 JLUR
Several
Certainly looking forward to hearing your thoughts.
Taxman
Alex
Raleigh, NC
CPA
As promised. Toyo AT3s in 35x11.50R17. Installed a 1.5/1.0 Traxda lift kit to level out the Jeep and maintain stock wheel well spacing. Lift is mild enough where no extended sway bar links are needed. Steering geometry isn’t affected enough to need corrections.
Drives great. Tires are about the same as the stock BFG KO2s but slightly larger. Actual height mounted and inflated to 37psi is 34”
Mikester86
2022 JLR
These tires are on my list. Would you recommend them?
Taxman
Alex
Raleigh, NC
CPA
Absolutely. I’ve had them on for about 6k miles now and two wheeling trips. Holding up well and great on snow, ice, rain and all conditions. Like them as much as the BFG KO2s. More aggressive tread pattern is a little noisier on highways but not terrible.
Mikester86
2022 JLR
Does the spare fit on the stock tire carrier? I also have a JLUR in white. But I have the steel bumpers.
Taxman
Alex
Raleigh, NC
CPA
Yes. Spare fits just fine without the need for spacers, longer bump stops or anything. About 1/2” of space to the stock plastic bumper.
Mikester86
2022 JLR
I wonder what the difference is, if any, between the steel and plastic rear bumper as far as the spare tire cut out.
cpawlFL
I ended up going with the Nitto Trail Grappler 35”x11.5”x17” tires mounted on an ICON Rebound 8.5”x17” rim. The wheels offer a 4.5” backspace and a -6mm offset. The tires have a C sidewall rating which I think will yield a softer ride. Here are a few pics of the wheel and tire combo!
Any adjustment to the spare tire carrier or it fit fine stock?
Mojito Mojo
Doug
GrayWolf.Overland
Subash
Port Moody, BC, Canada
2024 4xe Rubicon (Earl Gray)
Falken Wildpeak R/T 01 - 35x11.5R17 C on stock 4xe rubicon rims. ~ 89lb per side (tire+wheel)
Got very close, I wanted to be under 90lb to avoid tailgate sag. Mopar claims you can run a 37" tire on the reinforced tailgate - that is about 85-95lbs conservatively assuming they used BFG KO2 37s and mopar beadlock wheels.
Flip
Virginia
2023 Jeep Wrangler Sport
Jeep Wrangler JL More narrow 35in tires pxl_20231104_234641901-jpe
Nice choice, looks great bro! 👍
