GGspartan318
Ok thank you! And last question, should I invest in a torque wrench or is that not necessary? I think I would need a 3/8” one for this job to use with the 18mm socket.Should have everything you need. I believe the skid plate comes with all hardware. You will see in vid I attached, insert rivnuts, tighten them down to squeeze the rivnut to frame then remove bolt, then install brackets. Hand tools will do the job. They may even show what sizes needed on instructions.
