Mopar Roof Rack Mods (security, paint protection, + whistling SOLVED)
  1. OP
    paulr
    paulr Well-Known Member
    Vehicle(s):
    2018 Sting Gray JLUR
    Jan 17, 2018
    372
    Liked:
    553
    It’s not necessarily theft of the rack, it’s what’s in the rack. For example expensive skis stored overnight. If you can just remove the rack and take the skis and all easily then it’s an issue. Obviously anyone really determined will get it off regardless but a deterrent is helpful.
    Grateful1 likes this.
  2. Rubi2876
    Rubi2876 Active Member
    First Name:
    Vehicle(s):
    2018 Unlimited Rubicon
    Jan 1, 2019
    Dallas Texas
    Liked:
    That makes sense! Like if you have a cargo tub or something, its easier to just unbolt the rack and then off with the goods! I swear this world :( I'm debating on getting the Mopar or the Rhino Rack vortex R110. The mopars look like the stick out on the sides of the vehicle more than the rhino rack ones, also they look higher in the pics. My goal is a batwing awning so as tight as I can get the awning to the vehicle is the goal. I would like to have a rooftop tent and all the fun stuff but it doesn't warrant the cost. I don't want to drill into my hardtop, nor do I want a full gobi style rack because of gas mileage/daily driver.
  3. Grateful1
    Grateful1 Well-Known Member
    First Name:
    Vehicle(s):
    ‘71 VW Super Beetle / ‘98 TJ Sport / ‘18 JLU Sahara
    May 23, 2019
    Guntersville, AL
    258
    Liked:
    72
    I think I read on this thread or a previous thread the Thule lock works with Mopar RR. Replace the outside bolt with the lock.
  4. KDoc
    KDoc Active Member
    First Name:
    Kevin
    Vehicle(s):
    Grand Jeep Cherokee Unlimited 2015 Diesel, 2019 JL Overland ( Sahara in USA) on order .
    Jul 3, 2019
    Queensland , Australia
    Liked:
    41
    Occupation:
    Garage Profiles:
    Yes the end caps come off easy enough , I too installed an awning on the mopar roof racks .
  5. KDoc
    KDoc Active Member
    First Name:
    Kevin
    Vehicle(s):
    Jul 3, 2019
    Liked:
    41
    Occupation:
    Garage Profiles:
  6. Brian0128
    Brian0128 Well-Known Member
    First Name:
    Vehicle(s):
    2019 JLUR (ordered), 2018 Toyota TRD PRO
    Feb 25, 2019
    Annapolis, MD
    171
    Liked:
    171
    Occupation:
    Engineer
    Garage Profiles:
    How did you attach your awning to the Mopar rails?
  7. KDoc
    KDoc Active Member
    First Name:
    Kevin
    Vehicle(s):
    Jul 3, 2019
    Liked:
    41
    Occupation:
    Garage Profiles:
    The rails have slots so I had a local fabricator weld a washer to the head of an appropriate bolt then I filed two sides flat to the correct size to allow the new bolt to slide into the rail . There after just used the bracket supplied with the awning .
    Brian0128 likes this.
  8. DaveN007
    DaveN007 Member
    First Name:
    Vehicle(s):
    2020 Wrangler Rubicon
    Aug 10, 2019
    El Dorado Hills, CA
    Liked:
    Garage Profiles:
    That picture shows one crossbar mounted to the freedom tops. You aren’t supposed to do this. Here is what they look like in proper position. 3CA97201-EB9D-438C-89FD-5E44ADFD6FF4.jpeg
    Boatbuilder88 likes this.
  9. Goheels050917
    Goheels050917 Well-Known Member
    First Name:
    Dustin
    Vehicle(s):
    2018 Jeep Wrangler JLU
    Oct 11, 2018
    Raleigh - Durham, NC
    369
    Liked:
    376
    Occupation:
    SD-WAN Engineer - Technical Author
    Do you remember the settings you used on this? I have a cricut, but never uploaded the dimensions, etc to make it a perfect cut.
  10. AirportDave
    AirportDave Active Member
    Vehicle(s):
    2018 JL Rubicon, 2018 Grand Cherokee Trailhawk Hemi
    Jun 24, 2019
    Denver, CO
    39
    Liked:
    67
    I would sure love a set of these red decal inserts for my rack- if anyone has the Cricut and is willing to make me a set, I will gladly pay!
    And thanks for all the great install tips- my set up has zero whistling up to 80 mph, and barely noticeable wind noise at all.
  11. InvertedLogic
    InvertedLogic Well-Known Member
    Vehicle(s):
    19 JLUR
    Aug 2, 2018
    Denver, CO
    375
    Liked:
    278
    I've got a plotter and should have some red vinyl sitting around. I'll see if @paulr will share his file/dimensions with me.
  12. AirportDave
    Vehicle(s):
    Jun 24, 2019
    Denver, CO
    39
    Liked:
    67
    Man that would be great! I PM'd him, but haven't heard back. Since you're in Denver too, I'd throw in a cold beer or two also!
  13. OP
    paulr
    Vehicle(s):
    Jan 17, 2018
    372
    Liked:
    553
    yes that's been mentioned earlier in the thread already, the picture was pulled of a retailer's website I didn't make it myself, just used it to illustrate the various parts of the roof rack I am referring to
    It was kind of trial and error just kept squeezing/tweaking the height/width of the logo until it fit decently into the slots. The cut settings were just on standard vinyl.
    The file I have is just a cricut file, it won't work with another type of plotter. For the Jeep logo I just pulled it off the internet, you should be able to find a standard vector Jeep logo online to download as a starting point then just tweak the dimensions with trial and error until it fits
  14. OP
    paulr
    Vehicle(s):
    Jan 17, 2018
    372
    Liked:
    553
    This info has been added to the main post:
    PRINT YOUR OWN WIT THESE FILES: Due to overwhelming request I have posted the Cricut project files as well as vector files if you are not using a Cricut below. Please note these will most likely require some trial/error and adjustment on the dimensions, but this should get you really close as a starting point.
    Vector files: http://s000.tinyupload.com/?file_id=09444917626491268435
    Cricut file: https://design.cricut.com/landing/project-detail/5e5d3ddb7dd8b4069b19e189
    Cricut file: https://design.cricut.com/landing/project-detail/5e5d3e344c66f206a77638b6
    JLSpartan, weeitsmikelee and KeithM like this.
  15. InvertedLogic
    Vehicle(s):
    19 JLUR
    Aug 2, 2018
    Denver, CO
    375
    Liked:
    278
    :beer:
    I've got an old Cricut Expression (I think), that I bought specifically because I can use 3rd party software with it. I'll see if I can get those files to work on it.
Loading...
Share This Page
