paulr
- Jan 17, 2018
- California
- 2018 Sting Gray JLUR
Just wanted to share a few customizations I made to my Mopar roof rack, including solving the whistling issue which seems to have hit or miss solutions in other threads.
1) Red decals: I cut some red Jeep decals to fill in the Jeep logos to add a little bit of color and match the accents on Jeep
2) Paint protection: I noticed on my JK the roof rack did leave a little bit of marks on the hard top, so to avoid anything I cut some small rectangles of clear bra paint protection film from 3M in order to protect the paint where it grips, this also turns out to make it super easy and fast to put the roof racks back on and off exactly in the correct spot since the film marks the spot basically
3) Security: since these don't lock unfortunately, I decided to at least swap out the bolt inside with a torx security screw bolt, it makes it at least a slightly greater deterrent to get these off, most thieves are unlikely to carry this special torx head around... anyone looking to do the same you'll need M6 screws with about 25 to 30mm in length, I used this kit off Amazon: https://www.amazon.com/gp/product/B07CCMVJQW/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
4) No more whistling! The whistle is pretty bad on these once you hit 65 mph. In another thread some had mentioned putting tape along the bottom center, some on the sides... people were having mixed success. The key is to put tape on BOTH the bottom middle AND the side parts, shown in areas 1, 2, and 3 in this image below I marked up ... I tried it with just the middle and just the sides and it still whistles, you need to do all parts numbered here to stop the whistle completely
Once I figured out what worked, I wanted to come up with a solution that looked nice. Ended up cutting some black matte vinyl decals and stuck them on the bottom. They're basically invisible and this has stopped the whistling noise completely. You can't tell these are on here at all they blend in with the rack. The key is to cover all the groves and exposed areas on the bottom
Update: Finally got to give these some good use on a long ski trip, no whistling still and no issues
Update 2: Almost 17 months later these are still good to go, no issues with the vinyl coming off or anything
EDIT: I CAN CUT THESE FOR YOU IF YOU'D LIKE: Due to tons of requests I cut a handful of these for anyone interested and if I run out I can cut them for you in a couple days usually. Shoot me a PM for a PayPal link if interested.
$40 for the anti-whistle strips on the bottom
$12 for the red Jeep logo inserts
shipping included
EDIT: PRINT YOUR OWN WITH THESE FILES: Due to overwhelming request I have posted the Cricut project files as well as vector files if you are not using a Cricut below. Please note these will most likely require some trial/error and adjustment on the dimensions, but this should get you really close as a starting point.
Vector files: http://s000.tinyupload.com/?file_id=09444917626491268435
Cricut file: https://design.cricut.com/landing/project-detail/5e5d3ddb7dd8b4069b19e189
Cricut file: https://design.cricut.com/landing/project-detail/5e5d3e344c66f206a77638b6
shipping included
