Martinimaxx
- Max
- Mar 15, 2018
- Medford, OR
- 2018 Jeep Wrangler JlU
I have a pair of the mopar molded side steps for the jeep wrangler jl 2018+ 4 door. Used them for about 10k miles. They work great and never had a complaint but I ended up getting rock sliders and took these off now
They are used and have plenty of little scratches and dings from the trail and regular wear and tear. Pictures are from when I took them off on 4/11/19 (probably should have cleaned them up a bit)
Aside from the cosmetic damage the only other thing of note is that one of the 10mm pinch seam bolts broke off when I was originally installing these. It is the passenger side step and it's one of the bolts that is essentially under the rear passengers side door.
I have used it without that bolt for about a year (still attached by 3 13mm bolts to the body and 5 more 10mm's to the pinch seam) and never had a problem.
I do not have the mounting hardware (normally 3 13mm body bolts and 6 10mm nuts that secure to the pinch seam per side) my Rock rails reused the same set that this came with. But I'm fairly sure that's a quick trip to the hardware store for who whoever gets these
