Mopar Lift w/ 33" Tires?
AcesandEights
Aces
So. Oregon
2022 Jeep Rubicon 2D, with extra guacamole
Different strokes and all that.
Discount Tire
Peak Sponsor (Level 2)
Arizona, USA
discountti.re
All Things JEEP
Tire & Wheel Specialists
Thanks, Discount Tire… you guys also hooked me up with my new tires!!!
That's awesome, thank you for your business.
Punkn89
Alex
Maryland
2019 Wrangler JLU Sahara
Give it time, you'll be on 35's soon enough. Then you'll want 37's. Tire happiness only lasts so long, especially seeing all the badass rigs on here!
Reinen
2021 Jeep Wrangler JL Rubicon
Not necessarily. As tires get bigger, range gets smaller.
I've said I need greater range multiple times. There's no way around it. I've never said I need larger tires. There's always a way around that.
Punkn89
Alex
Maryland
You mean, you haven’t said you need larger tires….yet.
pfletcher229648
Patrick
Orlando
2022 JLUR XR w/SOT, 2024 JLUR X w/SOT(On Order)
CIO
I am posting this as I researched this site frequently regarding adding a lift to a JLU Willys with 33" tires. I have a 2021 Willys, JLU. I first swapped out the 32" M/Ts for 285/70/17 A/Ts… huge difference in ride quality and performance. I then added the Mopar 2" lift. I was skeptical about how it would look based on previous comments. First of all, it looks great, I can't be happier. More importantly, the Jeep rides much better… control, responsiveness, you name it.
I am not looking to crawl over boulders or do anything extreme; however, for an everyday driver that enjoys hitting the trails to get to remote locations, this set-up is perfect. I hope this helps others who are contemplating upgrading their Jeeps.
Jeep Wrangler JL Mopar Lift w/ 33" Tires? 1671555025219
Great looking ride.
Reinen
No, I don't. When you wheel 100 off-road miles from the nearest gas station larger tires and reduced range is decidedly unappealing. There's already enough range concern as it is.
AlgUSF
Melbourne, FL
2021 JLUS, 2014 Tundra, 2013 Odyssey, 2002 Civic
Three words "auxiliary fuel tank"
txj2go
DFW
I did that in Canyonlands- from nearest gas station to our farthest camp was over 100 miles, then we had to drive that back. Nearly half of that was on technical trails which cause my Jeep to drop to 10mpg or just under. I carried a 5 gallon can but ultimately didn't need it.
EMpunker
Ryan
Newport Beach, CA
2021 JLU Rubicon V6
I love the look. I'm actually going down in size from 35's back to 33's
Reinen
That's the area.
What can really screw you out there is that you think you're 20 miles from gas, then you discover that a flash flood washout or a rockslide made the trail utterly impassable. Which forces you into an impromptu Plan B that could be a 100 mile backtrack.
And by "utterly impassable" I mean I've seen trails I planned to take go straight off a 50' vertical cliff. Well, there used to be ground there. That's a bit of a problem. Large tires won't solve it.
JL ME
JOHN
Portage Wi
2021 JL Willys ,2006 Roadking , 2008 Hayabusa
Industrial Maintenance
Looks Awesome!
i have a 2021 2 door willys.
i have a 2" Mopar lift sitting in my garage. its been there for 6 months while I'm trying to figure out tires. I'm thinking 34"
