Mopar Lift questions for 2020 Rubicon
jimim
NEPA
2020 Rubicon, 2017 Tahoe LTZ
Ok. So deff no added weight to front then stock with my steel bumper package. I will be pulling a 16 foot bass boat. Wheeling will only be logging trails. Wooded trails. Stuff like that.
JayJay
Johnny
North Georgia
'20 JLR
Jim, if you aren't currently going to a larger tire and you don't see any rake, why do you want to change anything?
Later,
Johnny
jimim
NEPA
Johnny,
This all started cause I wanted like another inch out the stance cause I really like the look on the mohave. I know its just an inch but it looks really nice. I didn't want to go higher cause I don't need it, but I also want to get 35's eventually.
I was just going to do the 2 inch lift cause I also wanted the fox shocks and I thought the 2 inch lift was just that 2 inches. So 1 inch on a rubicon.
Then you guys educated me and I found pics of the factory tires on the Mopar lift and it's wonky cause I wouldn't have 35's on it yet.
Then I was given the idea of the coil spacers to just get that little bit of height I wanted, and then the leveling idea popped in my head cause I know I would get a little more height
jimim
NEPA
Ok so my final plan. I’m going to level the Jeep. They are going to use 3/4 inch spacer up front. Bit I’m also adding the 2.0 fox shocks.
Then down the road I can add the 35’s with factory rims.
nothing crazy. Leveled Jeep and better shocks. I just hope the 3/4 inch spacer is the right height to level but if not a different set is cheap anyway.
RAMSTEEL
Rick
Virginia
2023 392 XR
Army (Ret), Fed Guy
The bump extenders (I.) are a different part number in the AE crate. I just picked mine up today and compared the part list numbers. The instructions are also finally correct for spring locations :)
Jeep Wrangler JL Mopar Lift questions for 2020 Rubicon 20201222_171105
HeavyMetalFox
Chic-ette
Fruitvale BC Canada
2020 JLUR Recon Edition
RMT
That’s not correct, I’ve installed over a dozen in the past 2 years, and never had one be exactly 2” there’s no way it will only lift you 1 inch higher than you are stock. Rubicons included. I’m guessing best case you’ll get 2.5” of lift, worse case 3” or over. That being worst case because with that much lift you’ll have to purchase and install extra parts in order for it to drive sweet.
Which extra parts are you referring to?
