rubiconman
Besides the correction pads, would I need any other spring related hardware? I see there is a RK coil kit, and also the coils only. Do you think the (front) RK07727K - Diesel/Hemi Swapped - 2.5" and the (rear) RK07843K - DIESEL - 2.5" coil kits would be the correct kits for my application?I am running Rock Krawler 2.5" coils front and rear in combination with the correction pads. They provide less lift than the Mopar springs IMO. The trick here is that you are most likely going to need to replace both front and rear coils as a set, I would not replace just the front coils with another brand.
My opinion: Remove anything you added (RK pads, etc.) and take it back to the dealer and make them make it right. This is a warranty/installation issue. This will also ensure the Jeep warranty on your lift is intact and the dealer wont give you BS in the future.
I thought about that, but what are they going to do? Keep my jeep for a couple days, have the same guy who let it leave like this 'fix' it by getting it to where it has just enough room to not rub. Even then, they can only get it as 'right' as the kit was designed. The more I think about the kit requiring non oem parts to straighten the coils and not providing a correction for the tracking, the more I think this kit is sub par in design.
I really liked the idea of getting a manufacturer approved/designed kit that was functional, reliable, and preserved the warranty... but so far it has been a bit disappointing. I am learning a lot about my first jeep though!
