rubiconman
I had the dealer install a 2" Mopar lift on my 2023 JLUR diesel. I was aware of the bowed spring issue and checked for it when I picked it up... sure enough the passenger side was bowed pretty bad and the tie rod was real close, but not rubbing.... the driver side was bowed, but not as bad and the tie rod had good clearance. I ordered the RK correction pads and installed them and that made the problem worse. Then I noticed the dealer installed the front springs on the wrong sides in the front, so I swapped those. That did not fix the problem.
I know the mopar lift manual says the springs should bow outward, but these are bowing forward and backward. Should I try putting the Mopar pads back under the coils, now that they are an the correct sides? Or does the swaybar and/or tie rod need to be adjusted? Or did I get bad coil springs.
The only two parts that I added (beside the mopar kit) was the RK coil correction pads and the AEV stamped geometry correction brackets.
DRIVER SIDE:
DRIVER SIDE:
