Mopar LCA swap
unsavory
Jimmy
2022 JLUR XR 2.0T Auto, 2019 JLUR V6 Manual (sold)
Amazing post, lot of info here. I just got my 2023 JLUS and just came here because the steer is very unresponsive (compared with other vehicles i had). Only "mod": installed 275/70/18 ko2 at the dealer, NO lift.
Can you tell me exactly which part # do i have to buy to fix this? The Mopar LCA, two of them? (I´m new in the Jeep world but i´m loving it!!)
I don't believe installing longer control arms will help with "unresponsive" steering. If anything, the additional caster will make it less responsive, which is what most people are after.
Lower caster causes twitchy steering, and people like to increase their caster to keep it tracking more straight. Not to increase responsiveness.
These control arms shouldn't be needed on a stock sport with no lift. Something else seems like it might need addressing.
Paulcardona
Paul
Colombia
JLU SAHARA 2023
It´s a 2023 Sahara 4dr with 100 miles on it. I don´t know if unresponsive is the correct word, i mean
it´s very vage and i have to correct all the time.
If i move it a little bit it doesn´t go anywhere, i need to really move the steering wheel to cross.
It´s very soft too. And it doesn´t return back as good as other cars when i do a turn.
That LCA swap will help on this conditions?
Thanks
unsavory
Jimmy
Thanks
No probably not.
Sounds more like a steering box issue. You can search this forum for lots of posts about "loose steering and wander". FCA has released several versions of their steering box attempting to rectify this issue, and for the most part, it is much better now. However, sometimes you can get a bad one still.
Could also be improperly torqued ball joints from the factory (a common issue), loose tierod, etc.
Since it's brand new, take it back to the dealer to address. It's under warranty.
Edit: forgot to mention, but check your tire pressure. They tend to come over inflated from the dealer, which can cause wander as well. Try 35 PSI and see if that helps.
Paulcardona
Paul
Colombia
JLU SAHARA 2023
No probably not.
Thanks a lot.... i did 275/70/18 brand new and that´s the only thing changed from factory, they set at 32 PSI.
I mean it´s not something that you feel broken or really bad, i just tought with this LCA swap it will be a little better.
Jtphoto
Thunder Bay ON
Higher caster does help steering wheel return to center specifically and that is why higher caster tracks better.
People who are use to IFS rack and pinion steering will ALWAYS have to get use to the feel of conventional straight axle steering .. There are a number of reasons Jeep steering can feel vague. Number one being wide sidewall tires. The wheels can actually flex within the tire before the tire moves. “ As a Trial only” Put 50psi in the tires to remove that flex and go for a short run to see if that’s what you feel, then reduce pressure back to normal. . It greatly comes down to what vehicle you are coming from.. If you are use to a sporty little car with low profile tires then you will be definitely be disappointed with Jeep Wrangler handling. No way to sugar coat that it’s not a sports car. For instance, this last week I have been driving RAM 1500 Express with Low profile factor tires IFS. Handles nice but rides like a buckboard to my XR on 35s and 2.5” lift. Handling is more responsive in the RAM, but is it better? That depends on you. Personally I prefer the feel of the Wrangler steering and don’t find it vague at all. That being said you should be able to hold the Jeep steering wheel in one position on the highway and it should not drift what so ever.
The Jeep is definitely a different animal and can handle very nicely and competently on the highway at speed even on bigger tires but it MUST be set up and lifted properly to do so.
Paulcardona
Paul
Colombia
JLU SAHARA 2023
Thanks
Because of my problem.... should i get a fox ATS Stabilizer ?
blnewt
New Mexico
Just ask @cosine he knows!
Typically caster will be around 4 for stock Rubicons, around 5 for a stock Sahara and a bit higher, maybe 5.5 for stock sports. You may be on the low end for a Sahara so you may have more wander than what is typical. They have bubble gauges on amazon that you can get a fairly accurate caster reading with. If your caster is 5 or less those longer Mopar lift LCAs will help a lot w/ your steering if it's a caster issue.
https://www.amazon.com/Johnson-Level-Tool-700-Magnetic/dp/B00004T807/
Jeep Wrangler JL Mopar LCA swap 1674971898362
Paulcardona
Paul
Colombia
JLU SAHARA 2023
Thanks i will check that out!
Jtphoto
Thunder Bay ON
I am curious as to where you got these caster numbers as all Wranglers have the same suspension parts. There is no lift in a regular Rubicon. See other thread comparing stock heights. Even the XRecon 1.5 “ lift does not put the Rubicon caster out of spec.
blnewt
New Mexico
Going by the below FCA specs, the whole JL line ( no mention of the newest XR version) the caster range is a low of 3.8 degrees to a high of 6.35 degrees. FCA rather than supplying the correct LCAs they just widen the spec so they can use one LCA part # to cover all models. Each model has different spring heights, and with each inch in height gained about .75 degree caster is reduced (give or take). As far as the XR keeping caster in spec w/ that extra 1.5" lift, If they are indeed using the same suspension parts as a stock Rubicon (except for the taller springs/shocks) then something has to be changed to keep caster in range. IIRC the XR has different axle part #s w/ thicker tubes, it's probably been adjusted (welding the LCA brackets slightly different)to have an extra couple degrees tilt to keep caster in range. Maybe @Roky or @chevymitchell would have specifics regarding this.
Front Wheel Alignment Service Measurement Check Specifications
| Total Toe** | Caster | Cross Caster* | Camber - Left | Camber - Right | Cross Camber*
Sport | 0.20° +/- 0.20° | 5.35° +/- 1.00° | 0.00° +/- 0.50° | -0.25° +/- 0.50° | -0.25° +/- 0.50° | 0.00° +/- 0.50°
Sahara | 0.20° +/- 0.20° | 5.05° +/- 1.00° | 0.00° +/- 0.50° | -0.25° +/- 0.50° | -0.25° +/- 0.50° | 0.00° +/- 0.50°
Rubicon and 3.0L Diesel Sport / Sahara | 0.20° +/- 0.20° | 4.80° +/- 1.00° | 0.00° +/- 0.50° | -0.25° +/- 0.50° | -0.25° +/- 0.50° | 0.00° +/- 0.50°
Note: Caster values required to be greater than or equal to 4.0° for all variants
Speed331
Sean
Las Vegas, NV
2008 Jetta, 2018 Discovery Sport, 2020 Wrangler Sport S (on order)
Compared to a stock sport or sport s, the rubicon is 'lifted" . A stock rubicon runs 1.5" -2" higher than it's sport conterpart. Maybe .5" of that is in it's larger tires, but the remainder is in the suspension. The shocks and springs are both longer.
Look at it another way - if I wanted to put the mopar 2" lift on a sport - raising it to approx the same height as a rubicon - the kit includes the longer LCA's. Q.E.D. the rubicon should come with the longer LCA's stock as it already has a higher base suspension.
Jtphoto
Thunder Bay ON
A regular Rubicon is certainly not lifted. It has taller tires and Highline fenders. It also has exactly the same control arms, swaybar links and trackbars as the other models. See other thread for examples. I have measured all different models on the dealers lot and the most difference I have seen is 1/2” only in the front (not the rear) of a loaded Rubicon where it sat level where the Saharas and Sports more tend to have a rake. Back ends all the same.
The ONLY lifted Rubicon is the Xtreme Recon which has all the exact same control arms (already proven), 1.5” taller springs, different trackbars, extended bumpstops and swaybar links.
There is 0 information out there from Jeep that states the Rubicon has taller suspension.
FYI other then tires my XR was barely 1.5” taller in suspension than a Sahara it was sitting
beside.
FYI a Sport with a 2” Mopar Lift on 35s sits higher than my XR … FACT.
Jeep Wrangler JL Mopar LCA swap 37C6A6EC-A889-4168-B8AE-674D09D29762
blnewt
New Mexico
The ONLY lifted Rubicon is the Xtreme Recon which has 1.5” taller springs, different trackbars and swaybar links.
beside.
My stock 2dr sport with rubicon springs lifted approx 2", that's the only fact that I've dealt with personally.
