Mopar LCA swap
blnewt
New Mexico
Just ask @cosine he knows!
Got the LCAs in today and it definitely isn't as squirlly on the backroads. Do these readings look normal/ok? How big a deal is .4 difference from one side to the other? Should I take it back in?
Wouldn't worry about that at all, there's going to be variance. Glad you're happy w/ the drive, it's a great bang for the buck!
Markham
Maine
2020 Sahara High Altitude
🤬 those are on there good. I could not for the life of me do this on the ground with no leverage. I’m going to get an impact wrench that I’ve been meaning to get anyway.
With an impact wrench, it looks like I can reach 2 of the 4 nuts. Using it on the bolt side of the other 2 going to be a problem? I know I’ll need more torque on a bolt compared to a nut.
NULL POINTER
Carmine
Free state of Florida, NW of JAX
2023 Gladiator Rubicon, '19 VetteZ06 7spdVert,
Old Fart
I needed a 13/16 swivel head socket to get at my front passenger side bolt. Could not access the nut on that one because of the FAD. YMMV. My impact wrench supposedly delivers 1200 ft/lbs of breakaway torque. I didn't need it on the passenger side rear bolt, but I used it on the other 3.
I tried to loosen the bolt on the front passenger side with a 3ft cheater pipe on top of a 2ft breaker bar and could not get that one loose. Good luck with the swap, I am happy I did mine.
Gwagwv
Robert
WNC
Ford F-150, 21 JLUR
Thanks to @blnewt for the write up on LCA swap. I used ramps and was able to swap out my LCAs without much of a problem. Bolt holes lined up perfect. I Only had trouble torquing 1 bolt.
alignment numbers after are good.
Jeep Wrangler JL Mopar LCA swap 63B432DD-7F90-4CE3-A0F5-065F3E0A7D33
blnewt
New Mexico
And I bet you're a happy driver going down the hwy now too!
rickinAZ
Phoenix
@blnewt has helped a bunch of us improve our steering. Thanks Brad!
Qurtyslyn
Curtis
2018 Mojito JLUR
Got mine swapped today and the short drive I took was already much nicer. We'll see how it is on the highway tomorrow on my way to work.
blnewt
New Mexico
You're gonna love it!
itsbeenfunmike
San Marcos
2023 JLUR XR Firecracker Red
Govt Contractor
I just did this mod with the longer Mopar LCAs on my 2023 JLUR with the XR package. I cannot recommend enough that having a right angle impact is a must have to easily performing this in your garage.
I went with a M12 Milwaukee Fuel right angle impact. Took about 30 mins total.
Drives SO much better, so good in fact I can cruise the Highway doing about 75-80 with no steering inputs and it’ll track straight. No other steering mods.
The Chad
FPOI
XC90 dd. 87 YJ burned. 76 CJ7 sold. JKR sold
I had hoped the 2023 JLUR would have come with the Longer Control Arms.
blnewt
New Mexico
You'd think this would have happened years ago :( At least it's a simple & cheap fix if you DIY.
Swagger
Michigan
And a good excuse for buying one of those handy Milwaukee impact wrenches! My favorite DIY tool for the Jeep! I swear, these should come with it, with all the work you do after buying a Jeep.
blackJLURubi
Carson
Charleston, WV
2021 JLURD
Having trouble getting the bolt through the arm. How did you all go about this. I have pushed on the Jeep and still can’t get it to line up
