Mopar Flat Tow Harness arrived
Broccoli2
Santa Clarita
2018 JL, 2011 JK 1946CJ2-A
I ordered Mopar Part #82215382 09/02/18. I was told it hadn't been made yet and that I should expect it in December. It arrived the day before Christmas, I installed it yesterday. I almost gave up and bought a CoolTech. I didn't like the idea of having to cut wires and installing a switch ie, you would have to switch it to tow mode or drive mode and I don't believe it has a license plate light (I might be wrong on that one). The Mopar one was a bit of a hassle to install (very similar to trailer towing harness) but pretty much plug and play. The second you plug in the harness to the tow vehicle the lighting is switched to tow mode and vice versa. Super easy and keeps everything under warranty.
roaniecowpony
Retired Engineer
Thanks for pointing out there's a Mopar solution. A couple questions:
Did it come with installation instructions, including wire routing instructions?
What are you doing about tow brakes?
Broccoli2
Broccoli2
Santa Clarita
  • Thread starter
  • Thread Starter
  • #3
Yes it came with instructions, If you have ever seen IKEA instructions they are similar, haha. The biggest issue is getting the harness through the fire wall on the passenger side. The instructions say to remove the inner fender well lining. I found that I could reach up behind the liner from underneath. The other pain was removing the rear bumper to get to the license plate light. Beyond that, you just have to remove all the plastic on the passenger side from the front to the back. If your Zip code is correct I live near you and would be more than welcome to help out if needed.
As far as the brake I use the RVI Brake system. https://rvibrake.com/collections/fl...-auxiliary-braking-system?variant=20046642181 I also bought but have not yet installed the battery charger from the RVi site. The brake needs 12volt power and it has a short umbilical. The 12 volt on the dash is not powered unless the jeep is "on" but the plug in the back drivers side is always powered so I have an extension from the back to the front. I know there is a mod to make the front always powered, I saw it on this forum some where. I haven't decided whether I want to do that yet.
Jondrew
Bob
Central Fl
2018 Rubicon
I had an RVI3 brake system and charger on my CRV. It was very good. If you have the charge line running, can’t you just set the Jeep to accessory so the 12V plug is powered?
Broccoli2
Broccoli2
Santa Clarita
  • Thread starter
  • Thread Starter
  • #5
Not sure it would stay on unless you left the key inside and still not sure. But why not just run the extension to the back or do the mod to keep the front one on? I like to keep the doors locked and the key with me.
Springtail
Rock Sponsor (Level 1)
Doc
Southern Iowa
2018 JLUR, 1977 FJ40, (RestoMod), 2018 Camaro SS Convertible, 2020 Tesla Model Y Performance
Co-Owner Springtail LLC
Thank you....This is EXACTLY what I have been looking for!
Doc
Bilymac
Bill
Auburn, CA
2006 Ram 2500, 2017 Chevy Tahoe, 2017 Harley Street Glide Special, 2019 Jeep JLRU
How is the price of the Mopar Harness compared to the others out there?
Never mind.....found it for $368 on one site.
roaniecowpony
Retired Engineer
Thanks again. Yes, I'm in Torrance. I have a brother up by you. He has a CJ with a smallblock Chevy. I'm still figuring out what bumper/winch/towbar setup I want.
Bilymac
Bill
Auburn, CA
@Broccoli2, I believe @CoolTech has a jumper you can install to make the 12volt on the dash constant on.
Hypalon Man
Dennis
East TN
2012 Jeep Grand Charokee, 18JL, MB Sprinter 3500 based WGO Navion
Your 4 auxiliary switches.
2 40 amp
2 10 or 15 amp I forget.
Can be programmed from momentary or latching and be on with "key" or battery. Wiring is terminated under the hood and under dash passenger side. You could put a female 12vdc outlet under the dash for the brake system right?
Hypalon Man
Dennis
East TN
Pricey little devil.
Hgrace
Harry
Southern California
2019 JUL Sport S, Fleetwood 33 Terra SE. Lincoln MKC. Chevy 2500 HD
A bit late. Cool tech went in last week.
Works great
Broccoli2
Broccoli2
Santa Clarita
  • Thread starter
  • Thread Starter
  • #14
2 40 amp
Yep, you could. I however, don't have the switches
Bilymac
Bill
Auburn, CA
@Broccoli2, how's the Mopar harness working out for you?
WheelsASAP
