- Banned
- #61
Have seen on the Willys...you are in the clear.Perfect! Thanks for the quick response!
mand any deeper you need to pull your floor plugs and let water into the cab of the vehicle... unless you live in a very rugged remote condition and work as some kind of back woods rescue worker, I can’t really see this being worth it..I mean at some point you just got say this is a 40-60k vehicle I am gonna find a bridgeA basic wrangler is able to cut thru water up to 30" at 5mph. Why would you ever want a snorkel?
I snorkled mine and moved the breathers too, because i do cross water often, and the roads where i live are extremely dusty. seems to help keep my filter much more clean than without it. I wouldnt say its a worth while modification for city folk or mall crawlers. JMHOmand any deeper you need to pull your floor plugs and let water into the cab of the vehicle... unless you live in a very rugged remote condition and work as some kind of back woods rescue worker, I can’t really see this being worth it..I mean at some point you just got say this is a 40-60k vehicle I am gonna find a bridge
My understanding is that the Mopar CAI system and the snorkel both use the same cutout. If you look under a stock hood, you can see where there are provisions for future modifications.Sorry to revive this thread, read through it and was wondering if anyone here added the Mopar Snorkel to the CAI? In my case I ordered the Rubi with the CAI from the factory, so it came installed but without the cutout and hood piece. It seems that they did this marketing-wise so you could add the snorkel later? which then comes with the appropriate cut-out parts? Confused about it.
What temp sensor is showing 18 degrees cooler air?Oh goodie, I see a lot going on here.
First off, and I agree, don't rail on somone for doing what they want to do. We all love our Jeeps and all have ideas of where we want it to go! No harm in that. I am NOT a fan of angry grills, but if somone else likes it, go for it!
As for the cold air intake, this is always a slug fest. In terms of "cold air" the factory system is usually fair to middling. The problem is that in the hopes of keeping noise and costs down, the actual entrance to the system is usually under the hood and will pick up some degree of "Radiator" air, IE, already warmer than ambient. The Wranglers do have a tube from the grill that comes up under the airbox and helps, but it is not the best system.
I just love when the entire airbox is removed in favor of a cone system that no longer has any control over where the air comes from. A steel panel between the cone filter and the engine bay is a step backwards to me. Again, to each their own.
I went with the Mopar system for several reasons. Number one, as mentioned before, hood scoops, etc. do help by pulling air that has not already been heated.
Number two, the kit adds an exterior intake that circumvents underhood air. it is not simply a steel plate that has no way of controlling where the air comes from. I left the little air tube in as it adds more cool air around the airbox, which also helps.
Third, just like non-OEM systems, the intake runner between the airbox and throttle body is improved. In this case, the sound chambers are gone and the tube is considerably larger between the two. These changes do help. The cooler air is noticeable about 18 degrees on the temp sensor, and the larger tubing without restrictions helps in keeping a solid column of air pushing up against the TB. You will see improvements in this. Aside from the intake noise, which is cool, you feel the improved throttle response and the engine does pull a little better throughout the range and does not feel winded up high.
Lastly, the system is the best integrated into the factory system. It reuses the box, but adds the hood opening and the larger runner. It also come with a higher performance reusable filter, which is nice. Since it is made by Jeep, they would best know where they implemented noise control and cost mesaures and can readily defeat them. Also, its not voiding the warranty. My local dealer had never seen one installed until I showed up and they had a lot of questions about it. They like it!
So, do what you want. I just analyze everything and at the end of the day, the OEM system looked to be the best compared to "open" systems that don't nearly the open air the factory system gets.
If you look at the factory upgrade kit, there isn't a lot of modular capability to it. You could use just the improved filter, but why? Just buy that part alone if you want to.I wish they had a modular option, like you could add a piece to make it a snorkel or leave the piece off for a CAI. That would be the best of both worlds....
Nothing supplied when I picked up the Rubi- There was no kit (I've seen that kit in pictures- has the epoxy, alcohol, plastic housing and template), and when asked about it at the dealer- they had no clue. I have also found that others have confirmed that the kit was not included with the vehicle extras upon picking it up. Seems like up their alley to do something like that- to make the purchaser seek out the parts with little luck, then having to buy the snorkel to "complete" the kit properly. Just not sure...My understanding is that the Mopar CAI system and the snorkel both use the same cutout. If you look under a stock hood, you can see where there are provisions for future modifications.
There is a template, reinforcement bracket, etc. that go along with the CAI. They should have supplied the hood opening grill/cover, bracket, epoxy, etc. somewhere in the vehicle as it is part of the system. Otherwise, while you get the benefits of the larger runner, it is still wolfing in hotter underhood air.
