lembowski
Removed from a friends JL when he traded it in. In great condition, only “issue” is 3 of the 4 bolts included had to be reused on the traded in JL since Mopar tells you to throw the original hardware away. So you get the top mounting hardware, and 1 of the 4 bottom mounting. I did go buy 4 black oxide bolts that match the original specs of the bolts so you can mount it right up, but they don’t match the doctors torx. Mopar does not sell this hardware from what I could find.
https://www.quadratec.com/sites/def...tructions/Mopar_A-Pillar_Lamp_Brackets_JL.PDF
$80 shipped to you or local pick up in San Diego for less. I will be in Santa Clarita 22nd and 23rd if that helps anyone.
