Mopar 5 inch LED off-road lights! A-pillar install! Pics!
TallDude
Seattle Area
2023 JLUR-XR
Howdy all!
I actually took the time to document installing some lights 😁!
I gotta say, I’ve never really done something like this before. I took my time, read and researched the steps (probably 4-5 times) so it took me much longer going at my own pace but got it all done and it works, so goal achieved.
Love the plug-n-play capabilities of this kit.
Amazing light output (I’ve never had a-pillar lights before).
1) Got the lights from eBay for ~$320 shipped:
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! 0980ACCD-68FC-4E0B-ACFD-67F6AC9FA855
I went through the instructions one last time (also I read this) and got to work!
2) Removed the antenna (size 13mm I think).
3) Disconnected the battery negative terminal.
4) Removed the 4 bolts holding the cowl (T-30 I think) and set them aside.
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! F70CB813-5954-46EF-B086-E354B7BF4603
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! E664DBA6-9108-4221-AB9D-5AABDB5A753F
5) I ran the wiring for both lights along the recommended line/area as per instructions (in front of the top divider thing, sorry not sure what to call that, lol) and behind brackets for a coolant container.
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9051
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9052.JPEG
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9053.JPEG
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9054.JPEG
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9055.JPEG
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9056.JPEG
*I made sure to leave enough length for the cable to reach the lights!*
6) I then found and isolated AUX wire #3 (the orange one, very easy to find and clearly smaller gauge).
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9057.JPEG
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9058.JPEG
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9059.JPEG
7) I located the ground I was going to use, very convenient of Jeep to have left one free 😃!
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9060.JPEG
8) I then put the cowls back, test fitted the length of the plugs.
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9061.JPEG
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9062.JPEG
9) I installed the Mopar light brackets (82215427AB). I looked hard for the ones with the cut outs as I think they look much better than the filled version of these brackets! Got them from a Mopar dealer on eBay for ~$135 shipped. All required hardware came with the brackets. They have spaces and longer bolts so the brackets make zero contact with the Jeep.
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9064.JPEG
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9066.JPEG
10) I stripped the wires, got a waterproof heat-shrink connector (got a variety box at O'Reillys for ~$25) between the lights and the AUX-3 wire and I grounded the light wires.
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9067.JPEG
11) At this point I reconnected the negative battery terminal and tested things! Things worked (🥳) so I heat shrunk the connector (with a heat-gun from O'Reillys for ~$25) and installed the lights. I did take the lights off their "U" shaped bracket to secure that as the base and then bolted the lights up.
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9068.JPEG
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9069.JPEG
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9071.JPEG
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9072.JPEG
12) Congratulations on your sobriety...oops, wrong meeting/step...mmmmh. Now I zip tied everything to make it pretty. The kit comes with what seems like a lot of zip ties. I hard a difficult time getting them around the area the instructions showed...so I just did what I could and got them around. They kept going behind some glued on material that's insulation or fireproof stuff or both. Anyways I finally got like 3 outta 4 and called that good (I used a random spot for the last one) and got that all tidied up, then ziptied the what felt like 3 times the necessary length in wires to do the install and that was that!
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9073.JPEG
13) I reinstalled the antenna (size 13mm I think).
That's all!
Pics from Before/After.
Before:
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9047
After:
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9075.JPEG
Before (passenger):
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9046.JPEG
After (passenger):
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9074.JPEG
Before (driver):
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9048.JPEG
After (driver):
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9076.JPEG
Hope someone finds this useful!
These lights are AMAZINGLY bright. Makes me wonder if I still "want" the 7inch ones to mount on the bumper...
Yes it too me so long the rain on the Jeep dried up...😅 It was about 3 hours for me.
This really doesn't do them justice but it lit up my whole neighborhood (no joke)...
Off:
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9078.JPEG
On:
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! IMG_9079.JPEG
rohdawg
Long Island, New York
Merchant Marine
Looks good! Super satisfying to complete a project on your rig doing it yourself, isn’t it?
Nice work 👍🏼
Austin23
Michael
Austin, TX
2020 Jeep Wrangler Rubicon
Nicely done, and excellent documentation of the process. Your jeep looks awesome.
BullMoose1776
Bull
South Texas
Project Manager
Very nice. I also installed the "small" light, but from Rigid. I'm glad I didn't buy the bigger ones, I am very pleased with the output of the small ones.
That's a great color jeep, btw.
SRQgunner
Russ
Sarasota FL
2018 Jeep Wrangler JL Unlimted Sport S
Howdy all!
That's all!
Before:
After:
Before (passenger):
After (passenger):
Before (driver):
After (driver):
Off:
On:
How long is the mounting bolt? im looking at different cowl mounting brackets and the ones I like only have about 3/4 clearnce
Jeep Wrangler JL Mopar 5 inch LED off-road lights! A-pillar install! Pics! 1640916184674
JeezAJeep
Jimmy
NYC
2003 Baja..2019 BMW X2
I have the larger ones on my bumper...bright as hell...do you get alot of hood reflection with those?
RAO
Ray
NC
2015 JKU Sahara; 2022 JL Rubicon
Really good and great documentation on the build. Better to go slow and get it all right than to rush and have to go back and fix things. Keep in mind that if you disconnected the IBS, it will have to go through a learning process so the voltmeter reading will be different than before you started.
TallDude
Seattle Area
2023 JLUR-XR
@TallDude
hard to tell in the pics; does this setup allow your windshield to still be folded down without interference?
Yeah they would mounted as is. If you side mount them then you can fold the windshield down! That bracket offers either option to top or side mount II believe.
Cavs42
Owen
New Brunswick
2021 Unlimited Rubicon
Excellent walk-through! I'm going to be doing this sometime soon, but probably with KC lights. I will be using the MOPAR brackets though.
JeezAJeep
Jimmy
NYC
Very nice and bright
