Try Mopar part number 82210507ADAny idea where I can buy one? I have been googling for an hour unsuccessfully. Any help appreciated.
Thank you for pointing these out, I took a look and it looks like the connection is different to what I see on the pictures from install videos and the manual. Are you certain that these fit? Just want to make sure I don’t order the wrong thing by mistake.
I can't be certain. I would need to see the 5" offroad lamp and the connector to know if it fits. I have the 7" Mopar off road lights but I don't know if they use the same connectors as the connector on your 5" Mopar off road lights .Thank you for pointing these out, I took a look and it looks like the connection is different to what I see on the pictures from install videos and the manual. Are you certain that these fit? Just want to make sure I don’t order the wrong thing by mistake.
Many thanks!
I will do more research, it seems strange that such a common part seems so difficult to find. I also have a set of 7” lights coming, can’t wait to install themI can't be certain. I would need to see the 5" offroad lamp and the connector to know if it fits. I have the 7" Mopar off road lights but I don't know if they use the same connectors as the connector on your 5" Mopar off road lights .
Mopar has a helpline that could maybe provide the wiring harness P/N.I will do more research, it seems strange that such a common part seems so difficult to find. I also have a set of 7” lights coming, can’t wait to install them
Yep. Just generic Duetsch 2-pin DTP connectors.
Did you ever find the MOPAR part for this? Im in a similar situation.I just bought the 7” lights and realized they didn’t come with the wiring harness Has anybody found part numbers or similar replacements?
