Bocephus
Nope, not yet. I'd also like to know the same thing with the Dynatrac 2 inch lift on an XR equiped JLU.
Adding the Mopar lift to any XR will get you approx an extra half inch up to one inch of height, depending on weight of rig.
the XR coils are about 1.5” taller than standard Rubi
The 2” Mopar nets around 2” to 2.5” inches above a Rubi, depending on weight.
And so, moving from XR to Mopar 2” will net you about a half inch to an inch.
I think you’d gain very little moving from XR to Mopar 2,” in terms of capability. I would however recommend taking the front lower control arms that hare specified for the Mopar 2” and replace the front lower control arms that came oem on your XR. The Mopar 2” lift front lower control arms are a quarter inch longer, and will translate to better steering and road feel.
Imho, the XR suspension is perfect for 35’s. The Mopar 2” lift is not needed to run 35s (ie if you already have the XR), and it’s not enough to get best value from 37s…clearance will be limited, joints are not as flexy as aftermarket , and no adjustable track bars means your front axle will be offset from rear.
Imho, if you have the XR enjoy the suspension and get max use from those 35s. If you have a non XR, put on the Mopar 2” lift to run 35’s with max clearance…and probably add adjustable track bars. Any standard rubicon (or non Rubi) will benefit from the 2" lift to get max capability from 35s.
For 37s….For my money, I’d look at Clayton or MetalCloak lifts in the 2.5” or 3.5” range (3.5 for the win) to get set up for 37s. There are other quality lifts, but I like those two.
