Mopar 2 ' front coil spring isolators
JPS RUL
Michigan
99' TJ, 2019 Rubicon JLU
My lift was installed incorrectly by the dealer. 3 out of 4 springs were wrong. Had it fixed today, along with new front isolators. I believe they ordered stock isolators instead of ones for the lift? Part #s are 6834224AB, and 6834225AA. Does anyone know if these are the correct UPDATED isolators, or did the dealer screw up AGAIN? Thanks
mrbtd
Bill
Saint Johns FL
2018 Wrangler Sahara
The Rock Krawler pads are the only way to go. If you look @ the instructions for the Mopar lift it calls out using the stock pads so the installer did not do anything wrong.
JPS RUL
JPS RUL
Michigan
Thanks, Did you go with an adjustable track bar as well?
