Mopar 2” lift uninstall?
Doug997
Doug
MA
Expedition, Q5, JLUR 4XE (on order)
Looking for a bit of feedback. I have a 2019 MOAB and like my past JKU (Teraflex leveling kit) I want a bit of lift. I purchased the Mopar 2” lift, however after reading some review I was hesitant as most were getting 3.5”. Being a MOAB, it has the Rubcon suspension so I thought I would get the 2” as advertised. The lift is more for looks as I spend more of my time in snow than going off road.
So I had the lift installed along with Rock Krawler: spring pads, adjustable F/R track bars, adjustable LCAs and Fox steering stabilizer. My caster is +5.86/+6.06 after the alignment.
My 2” lift ended up being a 3 ½” to 4” which is too much for my daily driver. Additionally, I also installed 315/70R17 which equates to a 32” step to get inside.
I do not want to remove all the parts but know I need to remove the coils to drop it to a reasonable height (to me). I am looking to go back to the OEM (Rubcon) springs and add the Teraflex 1.5” spacer kit and keep all the other components installed. I added some details below and photos.
Note the sequence of install was MOAB with 285/70R17, then lift installed, then 315/70R17 installed (note that they do rub on the LCAs and I have SpiderTRAX spacers ordered).
So the question is can I remove the Mopar 2” lift coils and reinstall original coils with the Teraflex spacer kit and keep all the other components. I am sure an alignment would be needed again.
Doug997
Doug
MA
Sequence of photos from top to bottom...
#1 measurments
#2 no lift with 285/70R17
#3 Mopar 2" lift with 285/70R17
#4 Mopar 2" lift with 285/70R17
#5 Mopar 2" lift with 315/70R17
#6 Mopar 2" lift with 315/70R17
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
#1 measurments
Put steel aftermarket front and rear bumpers on and it will likely bring you down 1/2" and look pretty good with the 315's.
Or put 37" on it but that opens up other upgrades you like will want.
Kevin Mojito
Kevin
Washington
2019 JLUR Moijto 2005 TJ AEV Hemi
I used the Accutune Comfort Ride springs after the Mopar lift. It dropped about 1 inch.
Revolution_322
New Jersey
Jeep JL Rubi White
What exactly is your concern? Those springs are soft. Throw a bumper and a winch on with a tool kit and you'll lose an inch at least ...
Kevin Mojito
Kevin
Washington
Think he said he got 3.5-4 lift. I know mine was 3.5 - 3 7/8. I used the Accutune springs to drop it.
He can use the Teraflex spacers and stock springs, but will have a soft ride on the stock springs.
Doug997
Doug
MA
I am pulling off my Mopar lift springs and installing the OEM ones with the Teraflex ST1 level kit. I have a 2019 MOAB. I am planning to add a winch and the rear steel bumper, so I was going to go up a bit on the springs. I thought being a MOAB it had the Rubicon springs F/R but according to this table it does not. My OEM (came with vehicle) are FD/FP 659/660 and RD/RP 588/589. I was going to go with the FD/FP 660/661 and RD/RP 591/592.
As for removing the rest of the parts (shocks, arm-stabilizers, LCA) I will wait to see how thing line up.
My question is do the springs as ordered need to go on a specific side? In other words can I use my existing OEM spring FP 660 on my FD side? I will be reusing my Rock Krawler pads.
GT-Jim
Jim
SD
2018 Jeep Moab JL
CAD Designer
Doug, Where did you end up on your teraflex spacer project? I have the exact situation, I installed the 2" sport from Rancho on my Moab and it is way higher than 2". I also am thinking about the stock springs with spacers and leaving the rest of the parts as is. I'm not sure if I should use a 2" spacer kit or a 2.5" spacer kit.
