ran83ger
- Mike
- Feb 27, 2019
- Bear Creek, Pa
- 2019 Jeep Wrangler JLU Rubicon
Just a heads up, I installed the Mopar lift on my wife's JLUR and you may want to add a adjustable front track bar (I used the Steer Smarts Yeti) or you are more then likely going to have death wobble ( The front axle will be shifted out of center towards the driver side at least an inch) and you may want to get the Front spring Isolator correction pads to get rid of the spring bowing (I used Rock Krawler ones), I also installed the correction pads for the rear because if you measure both sides the passenger side will sit lower then the drivers side because of the gas tank location and extra weight.
