Loki Kai
- John
- Aug 22, 2019
- Wild Wonderful
- 2018 JL Rubicon
Take down notes before you confront management detailing each specific INCORRECT install issue. Then DEMAND a full refund. Explain that due to their obvious incompetence you are not comfortable with them correcting anything. Emphasize the install in its current state is potentially unsafe and your intention is to have it corrected by a QUALIFIED and KNOWLEDGEABLE installer. I would suggest a forum member with experience or an install shop that will READ and FOLLOW the instructions that came with the kit. I hope you got your bumpstop blocks and original parts back. BTW, something else to check are your lower control arms. Inexperienced installers sometimes only change ONE or neither because they assume they are the same as stock due to appearance. They look the same but have slightly different lengths. Again...GOOD LUCK!
